Question on Toyota axles #922229 12/24/08 11:20 AM
MainstreaM Offline OP
What's the scoop on toy solid axles? Good, bad, total junk? I'm pretty sure they are a passenger drop, but that can be gotten around. Posted on a couple of toy boards and got instantly flamed for mentioning toy and mitsu in the same sentence, bout as bad as the jeep guys <img src="/forums/images/graemlins/lol.gif" alt="" />
Kane
89 Conquest - 2.4 DOHC <--Thats right DOHC Turbo and MPI.
87 Starion flatsider - under restoration
87 Conquest - Saved from the crusher
86 Conquest - Another crusher rescue
88 Conquest - Previous owner abandoned project
87 Raider - under construction
86 Conquest - DD
Re: Question on Toyota axles [Re: MainstreaM] #922230 12/24/08 05:23 PM
ThatGuy Offline
www.pirate4x4.com/forum search is your friend
Re: Question on Toyota axles [Re: ThatGuy] #922231 12/24/08 06:06 PM
Tag Offline
I am not on the pirate forum. So please answer his question.
89 2dr 3.0 AT, manual hubs. 33x12.5 MT
gen 2 coils,Cranked front tbars
Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
Re: Question on Toyota axles [Re: ThatGuy] #922232 12/24/08 06:27 PM
The Pirate forum is not a place for Mitsubishi owners.
To the best of my knowledge only a small diff front axle was in country here other than the early FJ stuff.
Re: Question on Toyota axles [Re: MainstreaM] #922233 12/24/08 08:43 PM
Kane,
The Aussie version of the FJ60 (+) came equipped with full-floating rear axles and high-pinion front diffs. The ring gear and diff are similar to the Ford 9" with drop outs. With the exception of the Birfield joints, these axles appear regularly on crawlers in my area, often with 35-37" tires. Since the front axle is all plate steel and tubing, it is feasible to just swap the necessary pieces around for a driver's side drop. I've read articles that indicate overall component strength is approx. Dana 44-50 equivalent. I think they'd be good source axles for the Monty, even can sport Aisin hubs!! The Pirate write-up probably covers these bases more in-depth. The secret to posting there is "Dodge Raider"...:o
Russell
Re: Question on Toyota axles [Re: Tag] #922234 12/24/08 09:46 PM
ES_97Sport Offline
I hang aroud the Toy shops here because that's the closest I can get to a Mitsu shop.:-)
As I understand things the only problamatic part is the Birfields. Rock Stomper ran them for years with 37s and larger. Far as I know the ONLY thing he ever broke were the joints. Last axle I saw was using Porsche joints; they still broke.
The current 'trend' is to transplant D60 knuckles and re-do the axles shafts to fit. It's not hard or expensive. Basically you get a Ford 9" with Dana 60 knuckles when you're done strength wise. I've seen a couple done in the last few months.
Honestly? It's a waste of time. It's still cheaper to build a D44/D60 or a Ford 9" than to try and make a Toy or Mitsu axle do the same thing. It's kinda like trying to turn a Mitsu IFS carrier into a solid axle...why???
Re: Question on Toyota axles [Re: MainstreaM] #922235 12/24/08 11:04 PM
one up everybody with hybrid mitsu 9.5" with a front dana 60 and end up with sonthing cheaper and tougher than those ford 9" dana 60 combos.
This is what i've been looking into, and currie can make the shafts for this setup. Actually if you have the money you can send the 9.5" rear diff housing and they'll build the rest around that to fit your truck.
Re: Question on Toyota axles [Re: ES_97Sport] #922236 12/25/08 02:00 AM
1
1986powerram50 Offline
Im SASin my 86 truck w/ a yoter SFA and Ive read up on em purdy well and yes the birfeilds are the weak points on those axles but granted these yoters have CRAZY ass aftermarket options available example you can buy chrome moly birfs or a D44 knuckle conversion kit for the axle and if you can find the last year of the yoter SFA (85 i think) they are gusseted all to hell compared to the first years there just a bare axle granted you can buy the gussets
(sorry if this is a wee bit irrational my works Xmas party was "intense")
--keRby
Ad Inexplorta
Re: Question on Toyota axles [Re: 1986powerram50] #922237 12/25/08 02:21 AM
Mitsulvr Offline
Flipping a toy axle is pretty easy as far as I can tell. You can bolt the pumkin in upside down basically. The front of the diff has to be modified for the ring gears. And the nuckle balls need to stay on the same sides so you have to remove and reweld them. Also trussing, gears, axles and other parts are quite cheap in comparison for me being Canada. I cant even buy a CV shaft here. I'll post pics after the weekend I'm starting my flip boxing day. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Eric Wegerich
89 Montero as chopped as can be. Now with 5.29's
Re: Question on Toyota axles [Re: Mitsulvr] #922238 12/25/08 07:00 AM
sparkem Offline
They sell 30 spline chromo shafts for the front. Very very strong, but can still be broken with a stupid wheeling style.
http://longfieldsuperaxles.com
Pirate is a place for mitsu owners, I go there all the time. Just dont post about a hardcore Montero. I dont post much but I have learned a ton about other stuff.
PHP: 7.4.33 Page Time: 1.683s Queries: 16 (0.004s) Memory: 0.6436 MB (Peak: 0.7691 MB) Data Comp: Off Server Time: 2026-06-22 14:05:34 UTC
