Page 1 of 3 1 2 3
88 22RE swap to early 22R ???? #922374 12/25/08 03:48 PM
F
ffountain Offline OP
I have a early 22R that I'm putting in a 88 4wd w/22RE. What kind of problems will I encounter? I know electric to manual fuel pump to be an issue, but what type of wiring issues will I have? Not worried about gauges as I plan to install aftermarket oil, temp, and voltage gauges. I would like to use the ingnition system that is in the truck if possible.
Re: 88 22RE swap to early 22R ???? [Re: ffountain] #922375 12/26/08 03:51 AM
kewlynx Offline
You didn't make it very clear if you're completely going EFI to carb, or just using the long block. Am presuming long block swap with my response here.
Presuming 'early' means the round exhaust ports, you will need an early exhaust manifold in order to fit properly. Take a look at the 88's manifold and see if the O2 sensor is mounted there or not; that might be an issue.
On the head, you'd move the blockout plate from the 88's head onto the early head. The camwheel for the fuel pump won't be a problem, but if you don't want it, I'll take it. You'd then move the shim on the front of the 88's cam to your early cam, so it bolts back up okay.
Ignition system, the carbie ignition system is NOT THE SAME as for EFI, so all that's got to move, right down to the distributor, IIRC. Again, if it's the real early rig, the old alternators had an external regulator, so you can't use that for your EFI; seems to me the plug style is different as well.
If the early donor is out of a 2wd, you'll have to swap over the oil sump, pan, and dipstick, as they're different.
That's about all I can think of off the top of my head.
And NO, you can't swap head/blocks between earlier and later 22Rxx's, as the deck heights are different.
**ubi apis- ibi salus**
Re: 88 22RE swap to early 22R ???? [Re: kewlynx] #922376 12/26/08 12:51 PM
F
I'm completely going EFI to carb. I knew about the differences in the block/heads which made it impossible. The 22r I have is in great shape and the 22re is running but in need of a rebuild.
Re: 88 22RE swap to early 22R ???? [Re: ffountain] #922377 12/26/08 05:03 PM
F
So I'm really interested in what changes I have to make to go from electric fuel pump to manual and what I need to run the ingnition (power to starter from key, power to coil, and alternator and if I can bypass the computer).
Re: 88 22RE swap to early 22R ???? [Re: ffountain] #922378 12/28/08 05:10 AM
Scerb Offline
1st,just swap intakes and your efi system will bolt on / work with your 22r.
If you don't want to keep efi, all you need to do is get a fuel pressure regulator for the electric fuel pump (carb wants 4-7psi). The only electric wire you need is a hot wire to the choke, and hot/ground to the fuel cut solenoid. See my carb faq link in my sig for more info on the wiring.
I'd swap the EFI over to the new motor personally, although you didn't hear it from my mouth <img src="/forums/images/graemlins/ignore.gif" alt="" />
-Scerb
Re: 88 22RE swap to early 22R ???? [Re: Scerb] #922379 12/28/08 02:39 PM
F
I was under the impression that the 22RE EFI intake would not work on my early 22R head. Got my info here. Google/search this.
Just Imports, Dan Minick, Automotive Rebuilder, November 1998
This is where I got my info.
Re: 88 22RE swap to early 22R ???? [Re: ffountain] #922380 12/29/08 03:48 AM
kewlynx Offline
EFI and carb intake manifolds aren't the same critter.
Re: 88 22RE swap to early 22R ???? [Re: ffountain] #922381 12/29/08 01:00 PM
F
So, back to my original questions.
Re: 88 22RE swap to early 22R ???? [Re: ffountain] #922382 01/04/09 06:34 AM
Scerb Offline
So, back to my original post.
Re: 88 22RE swap to early 22R ???? [Re: Scerb] #922383 01/04/09 02:05 PM
F
I'm really interested in what changes I have to make to run the ingnition (power to starter from key, power to coil, and alternator and if I can bypass the computer)or if I even need to make changes to the ignition/electrical when swapping from EFI to Carb. Your FAQ doesn't cover these items.
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6382 MB (Peak: 0.7623 MB) Data Comp: Off Server Time: 2026-05-28 22:36:03 UTC
