Do they make a diff spool for the 87 montero 2dr stock rear end? #922707 12/28/08 10:48 PM
87monty Offline OP
Im not sure if they do but it would be nice to lock up the rear end!!!
2003 limited 20 year anniversary
96 SR
87 Montero SWB=Turbo diesel 4BT
T19 4sd with 205 transfer case
Re: Do they make a diff spool for the 87 montero 2dr stock rear end? [Re: 87monty] #922708 12/29/08 12:08 AM
justice Offline
No. The only aftermarket option is ARB.
Re: Do they make a diff spool for the 87 montero 2dr stock rear end? [Re: justice] #922709 12/29/08 12:21 AM
coalburner78 Offline
a handfull of 7018 rods melted in there should do the trick
87 raider,soon to have toy axles,TBI 318,R150 5spd,dana 300!. 78 ramcharger 5.9 cummins powered, 67 coronet 500 383/727
Re: Do they make a diff spool for the 87 montero 2dr stock rear end? [Re: justice] #922710 12/29/08 01:11 AM
87monty Offline OP
I herd some people are going with the toyota tacoma rear end for gear and locker options?
96 SR
Re: Do they make a diff spool for the 87 montero 2dr stock rear end? [Re: 87monty] #922711 12/29/08 03:40 AM
LandRaider Offline
Dunno where you herd that at, but no not really.
BobShaw is the only one I know of that put a yota axle in his truck.
DIY cheap swap is the montero sport locked diff, or weld your diff up.
Re: Do they make a diff spool for the 87 montero 2dr stock rear end? [Re: LandRaider] #922712 12/29/08 05:35 AM
PA_JERO Offline
Just a bit of advice in case you do decide to weld it up. Do not remove the thrust block in the center of all the spider gears. Not being to much of a welder, i had a shop do mine and they decided to remove my thrust block, at the time i didn't know it's purpose, but it caused a axle shaft to blow apart, no fun at all. <img src="/forums/images/graemlins/barf.gif" alt="" />
Re: Do they make a diff spool for the 87 montero 2dr stock rear end? [Re: PA_JERO] #922713 12/29/08 05:42 AM
powerRam50 Offline
my spider gears are welded to that thrust block,and everything else.
Re: Do they make a diff spool for the 87 montero 2dr stock rear end? [Re: PA_JERO] #922714 12/29/08 05:44 AM
well i recommend buying a sport rear end for 200-300 dollar range this will get you an air locker, stronger axle and in most cases disc brakes. It's a simple swap, but if you want to be a cheap ass, you can send me a bare diff (no ring gear) and i'll weld it up for you. Like PA_JERO said don't forget the thrust block.
Re: Do they make a diff spool for the 87 montero 2dr stock rear end? [Re: LandRaider] #922715 12/29/08 08:51 AM
87Montero Offline
I'd go with the locked diff option if you drove it on the street.. I drove Bob Shaw's truck with the Detriot locker in it.. it felt real funny driving on the road and punching the gas with the 4.3 making it lock the rear end <img src="/forums/images/graemlins/lol.gif" alt="" /> (lack of sway bars would do that too)
Yeah man, so what kind of wheeling you doing with your truck anyway? LSD rears work pretty well ya know?
Re: Do they make a diff spool for the 87 montero 2dr stock rear end? [Re: TOASTY] #922716 12/29/08 03:56 PM
87monty Offline OP
What year sport would have this air locker in it?
96 SR
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6441 MB (Peak: 0.7642 MB) Data Comp: Off Server Time: 2026-06-06 19:12:30 UTC
