coil spacers #922825 12/29/08 05:38 PM
O
odey Offline OP
I have just done 3inch lift to rear using 106 tj coilsprings and toyota rav 4 shocks now for the front i was wondering does any body now if a set of tj or zj coil spring spacers 2inch will work. My cousin has a zj 98 with coil spring spacers they look like the would work just wondering if it has been done. any info greatly appr.
99 kia sportage 2 door tj coil spring rear spacers in front 31x10.5 sidewider tires cat exaust in the process of making a snorkel
Re: coil spacers [Re: odey] #922826 12/29/08 08:22 PM
k120189 Offline
from what i've read 106 springs give closer to 4 inches of lift if your looking for spring spacers a member here makes them look for RSG another member evert makes actual strut spacers which moves the whole assembly down...with these parts available u can even out your kia
<a href="www.pittsfieldcustomsclub.com/sportage.html" target="_blank">98 sportage</a>: warn manual hubs,upyourkia spacers, 104 tj springs, 235/75/r15 BFG T/A KO, tracker rims, cone air filter, custom cat-back with a skunk2 muffler. gonna be a 2.3L
Re: coil spacers [Re: k120189] #922827 12/30/08 07:06 PM
Everet Offline
106's on my rig gave EXACTLY 4". As far as front spacers, email me at everet@upyourkia.com and I'll give you a quote.
Everet <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5922 MB (Peak: 0.6455 MB) Data Comp: Off Server Time: 2026-06-23 02:05:39 UTC
