Re: New Clearwater head causes compression psi to go through the roof [Re: weebur] #923319 01/07/09 01:19 AM
weebur Offline OP
I blew the edge off #4 exhaust valve 200 miles from home. I limped home and ordered a new casting w/o jet valves from Clearwater. Resumed the trip and put on 1,000 miles or so then checked the compression pressure yesterday. Old head ran 145-160psi with the new head 2-4 cylinders are at 186 and #1 is at 198psi. The FSM says it should be 170. I ran each test 4X with a good/accurate gauge. Anything to be concerned about?
It seems to be running OK except for a rattle/knock under light load that's in the lower end, probably #3 cylinder, but that was there before I replaced the head.
Well I couldn't believe that the compression ratio on the 2.6 was 7:1 so I pulled up all of the TSB's online along with repair data and engine specs. According to that source the compression ratio on the 2.6 (non-turbo) is 8.7:1 and 7:1 on the turbo engine. Anyway, tomorrow I'll start replacing all three timing chain guides and see if the rattle is from noisy chains.
Also, there is a TSB that increases the head bolt torque to 80 ft/lbs. on the 2.6, FYI.
'97 Jeep Cherokee XJ, Country, Black/Gray Leather, 4.0L, 4WD Command-Track, AW-4 Auto, 3.55:1 Gears, PowerTrax No-Slip Locker, Hi Country Tow Brackets, Spectre Air Filter, 235X75R15 Goodyear Wranglers, 126K miles
Re: New Clearwater head causes compression psi to go through the roof [Re: weebur] #923320 01/08/09 09:22 PM
TainterRacing Offline
Maybe the block has been milled down that would up the compression as well
1997 Montero LS with a motor swap a 1990 V6 12valve ported heads full 2.5in Ex I run stock tire size for Daily use, off road have 33x12.5 working on going trubo.
Re: New Clearwater head causes compression psi to go through the roof [Re: TainterRacing] #923321 01/11/09 06:25 AM
weebur Offline OP
That's a good point. I know some work was done on it before I got my hands on it, but I don't know exactly what was done.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5981 MB (Peak: 0.6519 MB) Data Comp: Off Server Time: 2026-06-22 14:13:39 UTC
