Page 2 of 4 1 2 3 4
Re: BEYOND FRUSTRATION !!!!! [Re: Kevin C] #924019 01/06/09 06:00 PM
tomzsix Offline OP
Hello, Kevin. sorry that i didn't stay in touch much. We have a new house now, and that takes a lot of care. I don't think that my truck now, would even make it to your house. The guys at work think that my cat is dead, and the particles build up after time and that create too muck backpressure and chokes out the carb. that might explain the exhaust smell in the engine compartment.
Tom Tucker
Re: BEYOND FRUSTRATION !!!!! [Re: powerRam50] #924020 01/06/09 06:01 PM
tomzsix Offline OP
Dan, where are you livin at now??
Tom Tucker
Re: BEYOND FRUSTRATION !!!!! [Re: tomzsix] #924021 01/06/09 06:29 PM
powerRam50 Offline
i am at the end of lombard near the napa warehouse,here in portland.i might be moving back to Springfield in a few months but i am here for now.st johns area.
Re: BEYOND FRUSTRATION !!!!! [Re: Kevin C] #924022 01/06/09 06:54 PM
Does the 86 have the same feedback carb as later 2.6s? If so, maybe pull the 87 Driveability FSM I have...
Re: BEYOND FRUSTRATION !!!!! [Re: MontyMcV] #924023 01/06/09 10:30 PM
tomzsix Offline OP
the guys at work think its the catalytic converter. Im still under warrenty, so they can check it out.
Tom Tucker
Re: BEYOND FRUSTRATION !!!!! [Re: tomzsix] #924024 01/07/09 01:41 AM
jmdt Offline
I had a buick station wagon in high school that did same thing and it ended up being the engine computer was bad. I don't know if that's of any help, but I feel your pain - it used to make me really mad!
Jim
1994 Montero LS
Re: BEYOND FRUSTRATION !!!!! [Re: jmdt] #924025 01/07/09 02:01 AM
If the Monty has the feedback carb, I have an ECU you can try / have.
Re: BEYOND FRUSTRATION !!!!! [Re: rxinhed] #924026 01/07/09 05:18 AM
tomzsix Offline OP
I'll try it. My cat converter and exhaust just checked out ok. They said that it most likely is the carb. The air fuel mixture isn't working. My truck does ok at below 20 mph, without stalling. At least i will save some gas!! what do I need to send you??
Tom Tucker
Re: BEYOND FRUSTRATION !!!!! [Re: tomzsix] #924027 01/07/09 06:18 AM
PM me your address. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: BEYOND FRUSTRATION !!!!! [Re: tomzsix] #924028 01/07/09 05:16 PM
ghostraider Offline
i do not mean to be rude but......What trouble shooting method are "they" using???
It sounds like your source is just guessing? well if that is the case then i hope this guess is correct <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" />
<img src="/forums/images/graemlins/zombie.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" />
Page 2 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.007s) Memory: 0.6404 MB (Peak: 0.7470 MB) Data Comp: Off Server Time: 2026-11-02 03:59:27 UTC
