Re: BEYOND FRUSTRATION !!!!!
[Re: ghostraider]
#924029
01/07/09 06:02 PM
They performed a back pressure test, at low rpm's and high rpm's. They said the readings show possible air leaks at the carb.
Tom Tucker
[Re: tomzsix]
#924030
01/08/09 12:48 AM
kind of what i was thinking.or maybe is has gotten a leak at the manifold to head?or one of the billion vac lines has a leak.
[Re: tomzsix]
#924031
01/08/09 05:45 PM
They performed a back pressure test, at low rpm's and high rpm's. They said the readings show possible air leaks at the carb. Sweet Work. I love When A decision is made with Intelligence and not being hurried or having to guess. <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: tomzsix]
#924032
01/10/09 04:33 AM
its been four days since the trouble. it sat in the driveway for a couple of days, and it drives without problems. I had to purchase a minivan for reliability issues. Now i can sit on the truck and take my time working on the problem. I will take others advice and start with the fuel tank and work towards the carb.
Tom Tucker
[Re: tomzsix]
#924033
01/16/09 02:45 PM
Found anything yet tomzsix?
I just found I have pretty much the same problem. The engine's fine on the lower part of the hill, but as I climb and press the gas pedal more, the engine violently coughs and dies. If I drop to first gear and crawl up the hill at low revs, then all is ok. Luckily, I live in a very flat area so hills are a weekend optional.
I've been told that it's the 2nd chamber in the carb that's not opening up when the required boost under load is needed. Not sure how accurate that is, but I'll be checking it out further.
Rob
[Re: RobCambo]
#924034
01/16/09 04:54 PM
Try an ignition coil. Theyre cheap, and easy to replace.
[Re: RobCambo]
#924035
01/16/09 04:55 PM
the second barrel on my blue truck has not worked in years,and it runs fine.it dont have any high end power but there is no cough or die.same thing with my brothers 87 monty before we put the weber on.
[Re: RobCambo]
#924036
01/16/09 04:56 PM
man i am sure glad i do not have a carb!
Maybe a can of Carb Cleaner?
<img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: LandRaider]
#924037
01/17/09 03:39 AM
why would you think its the coil?? Either they work or they don't, right?? I have never experienced a bad coil. How much are they? I am going to drain my gas tank this weekend and see what comes out. I don't trust my truck to even go to Kevin C's house. I would end up having to drive under 20 mph. Since now I have a glorious minivan, I can take my time on this trouble shooting.
Tom Tucker
[Re: tomzsix]
#924038
01/17/09 08:11 AM
why would you think its the coil?? Years of Experience Either they work or they don't, right?? I have never experienced a bad coil. Sometimes they fail, and stop working all together. Sometimes they fail, and short partially internally, and overheat. A weak coil will diminish under acceleration, and load. Ive troubleshot a 2.6 raider with this exact problem before. Swapped carb's, and computers, and all other things in between. About 20 bucks, and well worth your time to try. I am going to drain my gas tank this weekend and see what comes out. I don't trust my truck to even go to Kevin C's house. I would end up having to drive under 20 mph. Since now I have a glorious minivan, I can take my time on this trouble shooting.
Can't hurt to drain your gas, but i'd put a new coil in it first. Let us know whatever fixes it.
