heavy handed blunder #924940 01/10/09 10:49 PM
MAC Offline OP
while putting my locking hubs back on I managed to snap off the bolt that has the large flat washer that screws into the end of the axle. I assume smile the reason for it's existance is just in case the c-clip comes off the axle or all the hub nuts fall off the axle won't fall out or the hub won't fall off. Has anyone run for long without this bolt? I will drill it out at some point but no time right now. I had set the torque wrench then used it for something else (larger) and forgot to set it back... It really did not take much to snap it. dang
Re: heavy handed blunder [Re: MAC] #924941 01/11/09 03:16 AM
Adam F Offline
I dont think solid axle trucks even have one. I've only ever seen them on IFS trucks. Shouldnt be a problem. I havent ran any for years now.
97 4R, stock, daily driver
Re: heavy handed blunder [Re: MAC] #924942 01/11/09 04:37 PM
L
lawnmowerman Offline
Use a left handed drill bit.There is a good chance that the remainder of the bolt will thread right out.
Re: heavy handed blunder [Re: lawnmowerman] #924943 01/11/09 05:00 PM
MAC Offline OP
Yup. Those left handed drills are the best. Before using them I had miserable results with multiple types of extractors, even broke off a few easy-outs (then your dead). I have always drilled an initial pilot hole first then hit it with the lefty's.
Anyone out there who has never used left handed drills for busted bolts, studs, etc, do yourself a favor and get some of these. Soaking the rusty/old stuff with Kroil overnight before really helps also. I think EB endorses this method also. 'Nuff said.
Re: heavy handed blunder [Re: MAC] #924944 01/11/09 07:27 PM
OOP'S Offline
If the broken piece is not bottomed in the hole you may be able to take a scribe and catch an edge and un-screw it. I have done this a few time on the bolts that hold the felts on the knuckles on a solid axle.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: heavy handed blunder [Re: MAC] #924945 01/12/09 02:00 AM
wsquaredodie Offline
There ae special tools to get out busted easy outs. Ask a reputable machine shop.
trafdlo
Re: heavy handed blunder [Re: wsquaredodie] #924946 01/12/09 05:32 AM
KiwiCowboy Offline
You also need to use the right words while getting it out!
Re: heavy handed blunder [Re: KiwiCowboy] #924947 01/13/09 06:22 AM
E
EtienneNavaar Offline
As well as hold your mouth right.....standing on one leg could help too.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6203 MB (Peak: 0.7027 MB) Data Comp: Off Server Time: 2026-06-19 20:13:47 UTC
