Exhaust studs..where to buy? #925216 01/12/09 04:20 PM
Stevie Offline OP
Good morning all,
Need ONE exhaust manifold stud to complete a switch over from bolt-on on this 20R. Can't seem to find a 10 X 1.25 thread stud about 40mm long readily available. Standard thread for this size is 1.5. Did a search looking for a source with no luck. Does anyone here have one? Guess I could "make" one out of a long-threaded bolt, but would rather do it right. Thanks.
'80 4X4 Longbed
Re: Exhaust studs..where to buy? [Re: Stevie] #925217 01/12/09 05:08 PM
toyomorph Offline
japanengines on ebay sells a whole kit, if you can't find just one.
stud kit on ebay
canyon country explorer
1993 4x PUP
Re: Exhaust studs..where to buy? [Re: Stevie] #925218 01/12/09 08:36 PM
SALMONHEAD Offline
NAPA had the studs for my early 22r (1984) on the shelf.
84 4RUNNER,22R,HEDMAN,WEBER 32/36,Davis Unified Ignition,33" BFG
Re: Exhaust studs..where to buy? [Re: SALMONHEAD] #925219 01/12/09 09:01 PM
MAC Offline
got mine at the dealer. sold as each.
Re: Exhaust studs..where to buy? [Re: Stevie] #925220 01/13/09 02:33 AM
kewlynx Offline
NAPA parts bin.
**ubi apis- ibi salus**
Re: Exhaust studs..where to buy? [Re: kewlynx] #925221 01/13/09 03:37 AM
RatLabGuy Offline
Ditto on NAPA
Or you can get the cool extra long studs from LC Engineering, they aren't too much.
Question Reality.
Re: Exhaust studs..where to buy? [Re: Stevie] #925222 01/13/09 05:31 AM
wsquaredodie Offline
Studs suck. Always.. If you can see your way clear to pulling the manifold, heating the studs up and either unscrewing them out or drilling them out do so. Then rethread the holes and put in good grade 8 bolts with neversieze or equivalent. You will never have an issue after that. Studs will always go to pot - metal is lowest grade and do not stand up. Done dozens that way over the years....
trafdlo
Re: Exhaust studs..where to buy? [Re: wsquaredodie] #925223 01/13/09 01:49 PM
Stevie Offline OP
Never thought of NAPA....got one a few miles away.
Don't drive it much, have a leak right now anyway with the bolts, and have to do something. And that eBay kit is the first reasonable priced stud kit I've seen.
Thanks to all! <img src="/forums/images/graemlins/cheers.gif" alt="" />
'80 4X4 Longbed
Re: Exhaust studs..where to buy? [Re: wsquaredodie] #925224 01/14/09 02:58 AM
yodta Offline
you know, I was wondering about this myself recently, and wondering why they'd use studs in an aluminum head. I can think of a couple of reasons:
1.) it's easier (safer) to thread a nut onto a steel stud than it is to try to thread a steel bolt into an aluminum block, i.e., less chance of damaging the threads. I ask you, what's most likely to fail, the threads on the bolt or the threads in your block? especially given some of these funky angles. I mean, how many times have you nearly cross threaded a spark plug even?
2.) sometimes access to nuts and bolt heads is limited, as on manifold lower fasteners. maybe not so much on the 22RE, but just a general consideration. sometimes, there's simply not the room to get a bolt in and started properly, let alone get a ratchet on it if it's tight.
head studs make me nervous, too, but I've found that when installing a new set, I like to chase the threads in the block, clean & dry thoroughly, and then install the new ones with some plain old blue loctite, and double-nut snug 'em up. I'm a big believer in the antiseize, as well, and am considering using the copper stuff on a current project since it's supposed to hold up much better than the aluminum stuff on exhaust components, however, I'm not sure I *don't* want those nuts sticking a bit. perhaps if it were something I checked on periodically. it's the corrosion on the ends of the studs and nuts that tends to stick and make the studs back out of the head.
but anyway, I've had decent luck with studs at a local hardware store here called Taylor's Do It Center. I'm not sure just how *national* these guys are. newer Lowe's stores have a great selection of hardware, as well, or you might try a fasteners shop, or even your local machine shop. of course, there's always online vendors if you're really stuck.
msg - '87 xtracab
Re: Exhaust studs..where to buy? [Re: yodta] #925225 01/14/09 03:27 PM
Stevie Offline OP
What I bought:
Stud Kit
Thanks again folks. <img src="/forums/images/graemlins/kewl.gif" alt="" />
'80 4X4 Longbed
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6360 MB (Peak: 0.7604 MB) Data Comp: Off Server Time: 2026-05-31 22:46:47 UTC
