Page 2 of 3 1 2 3
Re: Towing with 95 SR [Re: MontyMcV] #925305 01/13/09 07:58 PM
V
vr4 Offline
http://www.valleyindustries.com/ISHEETS/81110.pdf
thats what was on mine when i got it. bolts to both the main frame rails and the part whenre the loop is. still have the loop on it too.
pulled a 4 door trooper with no problems. personally i would put a bigger (or a second oil-air) trans cooler on for any kind of distance towing.
87 Montero V6 SWB auto. dual bouncies
89 Montero V6 SWB 5 speed. dual bouncies
97 3000gt VR4 upgraded turbos, 10:1, E85
91 Stealth TT twin 18Gs, cams/heads, E85
03 cobra lightly modded <img src="/forums/images/graemlins/lol.gif" alt="" />
91 MR2 turbo
Re: Towing with 95 SR [Re: vr4] #925306 01/13/09 08:57 PM
Hans_GZP Offline OP
pulled a 4 door trooper with no problems. personally i would put a bigger (or a second air-air) trans cooler on for any kind of distance towing.
You think that thick trans cooler isn't good enough to cool that trans? That thing is pretty beefy, even by aftermarket trans cooler standards.
I have a valley tow hitch in my shopping basket for my one supplier, but I don't want to bolt it onto this montero since I'm buying another one over the weekend. I'm lazy and don't want to bolt it up, then take it off and bolt it to the other one LOL.
96 Montero SR
94 Dodge Stealth TT
92 Mitsu Galant VR4
91 Mitsu 3000GT
95 Mitsu 3000GT, carbon black, for sale
95 Mitsu 3000GT, white, for sale
92 Mitsu 3000GT VR4, silver, for sale
Re: Towing with 95 SR [Re: Hans_GZP] #925307 01/13/09 09:06 PM
95SR a/t locks up in 3rd and 4th, so there's not much if any additional tranny heating. Never had a prob towing the boat in summer with the a/c on in hilly NE GA...
Re: Towing with 95 SR [Re: Hans_GZP] #925308 01/13/09 09:28 PM
V
vr4 Offline
when it comes to cooling an automatic you can never have too much.
just make sure it runs thru the radiator after the oil-air coolers.
for the record i have a trans cooler out of a 6.0 powerstroke on my lincoln because i drag race it so much. i dont remember the exact measurements but its about 30x36"
91 MR2 turbo
Re: Towing with 95 SR [Re: fasteddy] #925309 01/13/09 09:52 PM
V
vr4 Offline
true. but mostly under light load. when towing its a whole different world. step into it just a bit and it will unlock.
off topic: how does the truck feel power wise hans? im still wondering if my crap rebuild is making the same power a normal SR should be. my only experience is when my GF ran into an SR that tried to beat her off the light. she took it by about 3 lengths to 70. who knows the condition of that truck though.
91 MR2 turbo
Re: Towing with 95 SR [Re: vr4] #925310 01/14/09 04:22 AM
Huh? Mine won't unless it downshifts or drops below some critical speed near as I can tell...
Re: Towing with 95 SR [Re: vr4] #925311 01/14/09 05:04 AM
That Valley hitch looks just like mine from the stealer. How much are they?
Re: Towing with 95 SR [Re: fasteddy] #925312 01/14/09 05:23 PM
V
vr4 Offline
made it a point to drive the monty to work today. TC doesnt lock up until in 4th. give it some throttle and it unlocks. give it some more and it drops to 3rd. give it even more and it goes to 2nd as the gas gauge drops.
regarding the hitch...i dont know. came on mine when i bought the truck
91 MR2 turbo
Re: Towing with 95 SR [Re: vr4] #925313 01/14/09 05:58 PM
Hans_GZP Offline OP
My truck feels real strong. I got 19 mpg on the highway on my first tank of 87 octane run through the truck. We were hanging with a SRT8 jeep through traffic LOL. I gave my engine a fresh rebuild. New piston rings, vss, big bore lifters, oil pump, water pump, timing belt and components, and gaskets and seals. I also replaced my trans cooler lines with some aluminum fuel line I had at the shop. Those were just about to explode LOL.
I think I can cruise at 75 mph at around 3k rpms. Truck feels real solid. I still have to do fluid and filter on the trans and check the diffs fluid.
96 Montero SR
94 Dodge Stealth TT
92 Mitsu Galant VR4
91 Mitsu 3000GT
Re: Towing with 95 SR [Re: MontyMcV] #925314 01/14/09 05:59 PM
Hans_GZP Offline OP
I can get them for about $210, but I'm sure you can find them cheaper at an online store. My distributor has 3 instock.
96 Montero SR
94 Dodge Stealth TT
92 Mitsu Galant VR4
91 Mitsu 3000GT
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6466 MB (Peak: 0.7582 MB) Data Comp: Off Server Time: 2026-06-23 09:46:22 UTC
