Towing with 95 SR
#925295
01/12/09 05:33 PM
I just finished rebuilding the engine on my 95 SR and put 500 break in miles on it. Now I need to tow some crap with it. It has the factory bolt on hook deal for pulling your truck out of a ditch and I have seen the bolt on hitch for that location. My question is: Is that bolt on hitch worth a damn or am I going to have major problems towing a car on a dolly with that thing? I wanted to see what other people have used for a tow hitch on this thing and what their tow limit was. I have bilstein shocks all around and I'm going to be putting some air lift air bags in the rear. I already had a 3000GT TT engine in the back of the truck and it didn't budge at all once it was dropped in... that was a pleasant surprise. So, basically I'm looking for a hitch that can handle towing 5-6000 lbs and I don't think the factory deal can handle that by the looks of it. If it can handle it, do you know where I can get the bolt on receiver part for the factory setup (if there is a place besides the dealer, obviously). Thanks.
96 Montero SR 94 Dodge Stealth TT 92 Mitsu Galant VR4 91 Mitsu 3000GT 95 Mitsu 3000GT, carbon black, for sale 95 Mitsu 3000GT, white, for sale 92 Mitsu 3000GT VR4, silver, for sale
Re: Towing with 95 SR
[Re: Hans_GZP]
#925296
01/12/09 07:10 PM
I don't know if it's still available from the dealer or not, it might have to be ordered but they had a really decent tow package that utilized frame mounts like standard tow packages as well as that tow hook mount... Mitsu dealer quoted me only $150 for it, but that was 2 years ago. They are probably out of stock for a Gen 2-2.5 by now. <img src="/forums/images/graemlins/frown.gif" alt="" />
1999 Mitsu Montero - Crappy Weather 1992 Isuzu Pickup - Zombie Apocalypse 2008 Saturn Sky Redline - Nice Weather
[Re: 87Montero]
#925297
01/12/09 10:19 PM
I bolted a receiver tube straight to the center mount and towed a 4k+ lb boat and trailer with no strain, with higher tongue loads than you should see with a loaded tow dolly, all on my 95SR. I had to drill two new holes in the flange, as the flange was really for a pintle hitch mount (same width, different top/bottom spacing).
[Re: fasteddy]
#925298
01/12/09 11:25 PM
I bolted a receiver tube straight to the center mount and towed a 4k+ lb boat and trailer with no strain, with higher tongue loads than you should see with a loaded tow dolly, all on my 95SR. I had to drill two new holes in the flange, as the flange was really for a pintle hitch mount (same width, different top/bottom spacing). Something like this? http://www.awdirect.com/buyers-prod...-5-8quot-pm812/trailer-hitch/?CID=BASE08
[Re: Hans_GZP]
#925299
01/13/09 12:56 AM
Harbor freight, Tractor Supply, Northern Tool to name three places I have seen the bolt on units.
Ed
Yankneck = Yankee ingenuity with Redneck stupidity. "How can I break it better?" 89 Raider 3.0 w/ 31's for now
[Re: yankneck696]
#925300
01/13/09 01:44 AM
I got lucky at a Pick & Pull. Found a bolt to frame Draw-Tite reciver hitch, wiring kit and trailer brake setup less than 50 bucks. <img src="/forums/images/graemlins/kewl.gif" alt="" />
You may need an adaptor to make the separate brake, turn signal bulbs work with the combo bulbs found on most trailers.
95 Montero SR 3.5 sitting on the sidelines. 96 Montero LS Daily driver. 88 Audi 90 Quattro marking it's territory. 69 Bronco built but uncut garage queen. TANSTAAFL
[Re: sewerrat]
#925301
01/13/09 01:50 AM
Hans GZP, if you can find a 2" receiver that only uses the 4 bolts that hold on the tow hoop, I'll swap it for my Gen II factory tow bar <img src="/forums/images/graemlins/kewl.gif" alt="" />
PM me if you're interested.
[Re: Mad_Scientist]
#925302
01/13/09 04:50 AM
This is like what I used...
[Re: fasteddy]
#925303
01/13/09 03:27 PM
This is like what I used... Sweet, I'll order that up today. Thanks!
[Re: Hans_GZP]
#925304
01/13/09 05:08 PM
I have the dealer receiver that mounts to the frame rails and the tow-hoop-plate at the rear, ~$165, IIRC. Also got the dealer plug-n-play four-pin harness, ~$50. It all installs efforlessly in no time. Still have the tow-loop as well.
