Page 2 of 14 1 2 3 4 13 14
Re: Off Roader's Gen II SR upgrade thread. [Re: OldColt] #925330 01/13/09 04:56 PM
off-roader Offline OP
Hi Ray,
I buy the timing belts for these from the dealer, the DOHC Mitsu engines are tough on the timing belt, the 6 cylinder less so than the 4s are but I have seen my share of 40K belt failures. A Conti brand belt has been the shortest lived belt so far.
The SOHC engines I will run any brand belt though.
Good point. In fact, I may just buy the whole kit and caboodle from them to be safe so I don't have to redo this until it's actually due.
Re: Off Roader's Gen II SR upgrade thread. [Re: off-roader] #925331 01/13/09 05:37 PM
I would expect the rollers might be a bit cheaper elsewhere but the belt and seals I get from the dealer. The seals add up in price but they run dryer than the aftermarket ones. I do not know if there is any difference on the tensioner, I happen to just had a tensioner failure on the DOHC engine in my Diamante wagon. Engine started a rumble at about 3500 revs. I drove it home gently and parked it till I can service it, I have no desire to loose a belt. Engine has 265K on it with about 30K on the belt, rollers and tensioner.
Re: Off Roader's Gen II SR upgrade thread. [Re: OldColt] #925332 01/13/09 07:54 PM
V
vr4 Offline
coil spacers for a sequoia fit perfectly.
waterpump ill go with GMB aftermarket or OEM. nothing else.
timing belt ive personally never seen a conti belt fail on a DOHC 6g (i thought the OEM belts were made by conti.) ill use gates, conti, power enterprises or OEM.
tensioner ill use OEM only.
idlers aftermarket are fine.
i may be able to piece together a complete 60k kit cheaper than you can find. depends on your sources.
87 Montero V6 SWB auto. dual bouncies
89 Montero V6 SWB 5 speed. dual bouncies
97 3000gt VR4 upgraded turbos, 10:1, E85
91 Stealth TT twin 18Gs, cams/heads, E85
03 cobra lightly modded <img src="/forums/images/graemlins/lol.gif" alt="" />
91 MR2 turbo
Re: Off Roader's Gen II SR upgrade thread. [Re: vr4] #925333 01/13/09 08:23 PM
The Conti failure I had was on a 4G63, a customers street driven GVR4 commuter car. Probably spent a bunch of time in the 2200 to 2400 rpm range that is the harsh spot on these.
A new belt I have in hand right now is labeled Unitta, defiantly not a Continental.
Re: Off Roader's Gen II SR upgrade thread. [Re: vr4] #925334 01/13/09 08:41 PM
Found a new Mitsu water pump and timing belt (OE not aftermarket) for a 95 SR 3.5L DOHC engine for $80 and $45 (respectively) from someone who was going to do their's but then sold their vehicle at the last minute.
He said he'd sell them both to me for $120. Good price?
Re: Off Roader's Gen II SR upgrade thread. [Re: off-roader] #925335 01/13/09 08:54 PM
monte3 Offline
I doubt you'll find it any cheaper... <img src="/forums/images/graemlins/shame.gif" alt="" />
98 Gen 2.5
05 Pontiac GTO
91 Corvette ZR-1
2011 Kia Sorento (wifey mobile)
Clarkdale, AZ
Re: Off Roader's Gen II SR upgrade thread. [Re: off-roader] #925336 01/13/09 09:29 PM
Mad_Scientist Offline
I paid $100 just for the OE TB on my truck. Snap it up! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Off Roader's Gen II SR upgrade thread. [Re: OldColt] #925337 01/13/09 09:33 PM
V
vr4 Offline
all the conti failures ive heard of were on the 4g63
91 MR2 turbo
Re: Off Roader's Gen II SR upgrade thread. [Re: vr4] #925338 01/13/09 10:00 PM
Well, that's not something I'm gonna be worrying about for hopefully a least 60k.
I'm picking up the belt and water pump tomorrow. Being as they're in his hands and not the dealer, what should I doublecheck to ensure they're fine?
Body Lift
As for upgrades, I stopped by 4crawler's today to check on getting a body lift for the rig. I know Cap510 also raised his gas tank over the frame rails. Was this done w/ a 2" body lift or a 3" BL?
Rock Skids
I'll be getting the rock skids next. Am vacillating between straight ones or having the ends kicked out 1 or 2 inches wider. Ultimately I wouldn't mind running a set of 37's but I intend to go to 35's minimum on this rig. What do you all think? Kicked out or straight ends?
That's all for today. Still need to resolve a EGR check engine light but that's a topic for a different thread. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Off Roader's Gen II SR upgrade thread. [Re: off-roader] #925339 01/13/09 11:21 PM
4xmonty Offline
Carlo's lift is 3"
Russ
GETTIN OLD THATS EARNED
Happy trails to you
(1)98 Montero SR RB Rock Crawlers BFG 33s Rancho 9000's OME Med coils rear
(2)95 4Runner All Pro Nerf bars BFG 32s
ARB bull bar
Downey 2" rear coils Downey headers
(3) 90 Montero LWB 3.0 auto
(4) 98 Kawi GPZ1100
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6528 MB (Peak: 0.7633 MB) Data Comp: Off Server Time: 2026-06-07 06:28:25 UTC
