rocker arms #926251 01/17/09 03:32 AM
topcat Offline OP
hi all new here
quick question?
i recently had my timing belt cam belt water pump done
since then very smokey and gutless
now have broken rocker arm
can this be attributed to recent work done as above?
swb 2.5 tdi
swb 2.5tdi
33" muds-50mm body lift-40mm OME rear coils-2.5"exhuast-ball joint flip-snorkel-unifilter air cleaner-added bonnet scoop for intercooler-ARB rear locker
Re: rocker arms [Re: topcat] #926252 01/17/09 05:55 AM
torquemonster Offline
yes, timing was set wrong and your piston hit your valves...very common with these engines to break rocker arms when timing is out and piston/valve make contact.
Re: rocker arms [Re: torquemonster] #926253 01/19/09 09:39 AM
lordtrunks Offline
Very true I have seen it on a 4d55 were all the rockers were broken because of out of time belt.
89 2 dr turbo diesel
89/88 "Backwoods sas"
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5924 MB (Peak: 0.6455 MB) Data Comp: Off Server Time: 2026-06-17 15:51:17 UTC
