trouble starting #926407 01/18/09 03:13 PM
riding4him Offline OP
Just put a engine in my 91' trooper. (2.8 4x4 auto) Having trouble starting it everything is hooked up imk pretty sure it will start but i have to pump the gas. Could it b bad gas, or a vaccum hose? It kinda smokes out the Throttle Body. Help!!
Re: trouble starting [Re: riding4him] #926408 01/18/09 07:43 PM
BigSwede Offline
Maybe the timing is way off?
Serenity now!
Re: trouble starting [Re: BigSwede] #926409 01/19/09 12:04 AM
I did remove the distributor cap could that be it? Cause i had the motor in another trooper right before i put it in my nicer trooper, and i drove it around and was fine. I didnt tear into the motor at all. If it is the distributor how is the best was to check the timing? Thanks for your help!
Re: trouble starting [Re: riding4him] #926410 01/19/09 03:12 PM
BigSwede Offline
The dist cap should go on and off without affecting timing...but if you twisted the distributor itself during install that would affect timing.
The only way I know of to check timing is the old-fashioned timing light method. Check a shop manual for the procedure.
Seems worth checking, the "smoke" from the throttle body says to me the timing could be off.
Serenity now!
Re: trouble starting [Re: BigSwede] #926411 01/19/09 03:24 PM
That sounds like what it might be. Thanks alot for all you help i realy do appreciate it!! Have a good day and God Bless!
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6035 MB (Peak: 0.6673 MB) Data Comp: Off Server Time: 2026-06-12 14:24:07 UTC
