'93 T100 3.0 5spd 4x, any rear diff interchanges? #926564 01/19/09 07:02 PM
G
GTFD Offline OP
Rear 3rd member pinion is very bad. Change out might be best option. Are there any interchanges for that pumpkin to other models or is T100 specific only? What ratio do I have? Thanks
Re: '93 T100 3.0 5spd 4x, any rear diff interchanges? [Re: GTFD] #926565 01/19/09 08:24 PM
ErikB Offline
Toyota Moderator
You probably found this if you read the faq over on Pirate...
http://home.4x4wire.com/erik/diffs/#T100-Tundra
And you can look at the faq here to see if your axle ratio code is in there.
PHP: 7.4.33 Page Time: 0.989s Queries: 15 (0.003s) Memory: 0.5864 MB (Peak: 0.6341 MB) Data Comp: Off Server Time: 2026-06-12 08:52:37 UTC
