Part numbers for the alternator belt tension pulleys for a 1993 Montero 3.0 #926918 01/21/09 06:11 PM
Troy24 Offline OP
Does anyone have part numbers for the alternator belt tension pulleys for a 1993 Montero 3.0? The serp belt has one smooth tensioner and one idler pulley.
The dealer was able to give me the p/n for the a/c tensioner but not the others.
I checked the Specialized Part Number Repository first but I did not come across the numbers.
Mine are starting to make some noise and there is a lot of fromt to back play in them.
Another question, Can these be rebuilt?
Any help is greatly appreciated.
1993 Montero SR 205,936 miles. BF Goodrich A/T's Dual Bouncy Seats.
Re: Part numbers for the alternator belt tension pulleys for a 1993 Montero 3.0 [Re: Troy24] #926919 01/21/09 06:23 PM
hazy_daze Offline
If it's the same as a 91 3.0, then the P/N is MD308882. Same for both of them. And no, they're not rebuildable, per Koyo USA tech assistance.
Re: Part numbers for the alternator belt tension pulleys for a 1993 Montero 3.0 [Re: hazy_daze] #926920 01/21/09 07:43 PM
Grasscat Offline
Michael j
TreadLightly! Trainer
Re: Part numbers for the alternator belt tension pulleys for a 1993 Montero 3.0 [Re: Grasscat] #926921 01/21/09 08:44 PM
hazy_daze Offline
Yep, you could do that too. I had them on mine and they worked fine. I just prefer the OE style when it makes sense to use it.
PHP: 7.4.33 Page Time: 6.726s Queries: 15 (0.003s) Memory: 0.6032 MB (Peak: 0.6590 MB) Data Comp: Off Server Time: 2026-06-10 02:56:41 UTC
