4X4 WORKING??? #927135 01/22/09 10:13 PM
RALFIRECAPT Offline OP
Stupid question here. Short of going out and getting stuck, how can I tell if my 4 wheel drive is working. I recently bouhgt an 84 CJ7.
Re: 4X4 WORKING??? [Re: RALFIRECAPT] #927136 01/22/09 10:38 PM
4x4Wire Offline
Put it up on jack stands, start the engine, put it in gear and see if all tires rotate.
Or, with that year of Jeep, with engine off and transmission in gear, shift the transfer case into high or low range and try to turn the front drive shaft by hand.
With the transfer case in neutral or 2-wd position, the front drive shaft should be free to turn.
Also, you would need to ensure the front hubs are locked in position.
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: 4X4 WORKING??? [Re: 4x4Wire] #927137 01/22/09 11:00 PM
BigJim Offline
By far the easiest way is to put it in 4 and make a tight turn on a hard surface... If you can make a complete circle and it isn't jumping and complaining, it ain't in 4!
Re: 4X4 WORKING??? [Re: RALFIRECAPT] #927138 01/23/09 06:02 AM
BobRowe Offline
The above suggestions will work.
Or you can have a buddy follow you onto a dirt road. Stop the Jeep and then tromp on it vigorously. Your buddy should see all 4 tires spin (or at least one front tire and one rear tire).
Re: 4X4 WORKING??? [Re: BobRowe] #927139 01/23/09 02:57 PM
DBL_DTY97TJ Offline
gravel parking lots are good for that...Don't be hangin' out behind the truck...
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6017 MB (Peak: 0.6661 MB) Data Comp: Off Server Time: 2026-06-20 15:40:44 UTC
