91 Trooper intermittent gauges #927715 01/26/09 09:23 PM
MeatWagon Offline OP
Howdy folks. I've got a problem that's bugging me. When my 91 Trooper was my daily driver (up until about 3 years ago) - the 3 gauges in the pod worked perfectly. After sitting for weeks on end, the gas and temp gauges started to work only intermittently. The oil pressure works 100% of the time.
I've taken the pod out and disconnected/connected the molex plug back there a few times- I thought maybe it had corroded....but the problem remains.
When they go out, they both go out at the same time...and when they work, they start working at the same time. So I think I can rule out the respective sending units. Is there a common +12v point for these two somewhere else on the harness? When they do start working they appear to be just fine...I think there's gotta be a loose connector I haven't found yet...
Thanks for any help -
Re: 91 Trooper intermittent gauges [Re: MeatWagon] #927716 01/27/09 12:21 AM
bamashooter Offline
I had the same problem on my 89 trooper. See the following thread. http://forum.planetisuzoo.com/viewtopic.php?p=140845&highlight=#140845
PHP: 7.4.33 Page Time: 3.852s Queries: 15 (0.004s) Memory: 0.5873 MB (Peak: 0.6359 MB) Data Comp: Off Server Time: 2026-06-23 14:26:18 UTC
