Page 1 of 3 1 2 3
Double GenII Whammy #928182 01/29/09 01:38 PM
stony-man Offline OP
This morning, my wife's '95 wouldn't start, because we couldn't turn the key, at all. I tried wiggling the shifter, the wheel, and it would not move at all.
So I load up the wife and 4 little ones in mine, and there's no fan power for the defrost/heat. Both daily drivers down at the same time.
Any suggestions on what to look at on these things? We've arranged a ride for the family, so I have to try to get them running ASAP.
Re: Double GenII Whammy [Re: stony-man] #928183 01/29/09 02:47 PM
87Montero Offline
Your gen 2's fan is probably just a bad connection at the fan, or in the switches....
I'd look at the fuses though first!
Re: Double GenII Whammy [Re: stony-man] #928184 01/29/09 02:48 PM
87Montero Offline
I'll be you the wheel lock is on, the wheel probably needs to be turned hard to whatever opposite direction it's being sprung to... Or, you need to to put the right key in the truck lol
Re: Double GenII Whammy [Re: 87Montero] #928185 01/29/09 02:48 PM
Got the '95 started...just kept messing with the ignition, and it finally turned...now it seems to work fine. I'm going out to look at fuses, etc. on the '92...it's only 24 out, and my drive is full of snow. smile
Re: Double GenII Whammy [Re: stony-man] #928186 01/29/09 03:46 PM
Between the two Pull-A-Parts up here there are three 92s and one 95. I think the 95 was an SR. FYI...
Re: Double GenII Whammy [Re: MontyMcV] #928187 01/29/09 05:24 PM
Thanks Bill. I may need to run up and pull a fan motor if that's what it needs...depending on the price/availability of a new one. I've got a mechanic (that I trust) who can look at it Monday...gonna be cold riding until then. :-D
Re: Double GenII Whammy [Re: stony-man] #928188 01/29/09 06:52 PM
87Montero Offline
5 bucks says its just a bad connection at the fan..
Re: Double GenII Whammy [Re: 87Montero] #928189 01/29/09 07:14 PM
Can you get to that without tearing the hell out of the dash? I don't even know where the fan is...hey, I've only been driving the old girl for 17 years, cut me some slack. <img src="/forums/images/graemlins/baby.gif" alt="" />
Re: Double GenII Whammy [Re: stony-man] #928190 01/29/09 07:37 PM
87Montero Offline
Check the fuses, otherwise its behind the glove compartment above the ECU, I'd recon..
Re: Double GenII Whammy [Re: stony-man] #928191 01/29/09 07:38 PM
PatrickS Offline
I went thru the fan problems a couple of months ago. I am not sure where it is located on a 95 but if you can get at it without to much trouble, try a direct connection from the battery. If it works then trace backwords. If it does not run then you have saved taking the entire dash apart. It does not matter how you connect it, it will run forward or reverse. Just see if it runs.
89 3.0 LWB Montero, 1st Gen, 5 Speed Manual, 5 Door
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6386 MB (Peak: 0.7631 MB) Data Comp: Off Server Time: 2026-06-22 05:59:55 UTC
