Page 1 of 3 1 2 3
Time to Lift the Cherokee #929729 02/06/09 02:54 AM
DBL_DTY97TJ Offline OP
It's almost time for the annual camping trip to Uwharrie and the GF doesn't want to get me another "If you're following me, you won't make it" T-shirt. Looking for a good 2" budget boost to set her on some 31's. Looking tonight all I see are add-a-leafs and shackles for the rear. I thought there were some BB's with full rear spring pack lifts available for around $250, but don't see any. Can someone point me in the right direction? Rubicon Express has one with rear lift blocks - Would that be a good alternative? Some of the others had rear shackle lifts. Let me hear it - good/bad/ugly! <img src="/forums/images/graemlins/smile.gif" alt="" /> Thanks! <img src="/forums/images/graemlins/cheers.gif" alt="" />
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
Re: Time to Lift the Cherokee [Re: DBL_DTY97TJ] #929730 02/06/09 03:06 AM
4x4Wire Offline
Check http://www.tomken.com
I used their 4" springs on my 89 XJ along with ProComp coil springs with 1" front spacer.
You need a drop-transfercase and longer brake lines.
That combo will fit 31" with very minor trimming.
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: Time to Lift the Cherokee [Re: 4x4Wire] #929731 02/06/09 03:46 AM
Nice stuff. I'm more for the $178 2" BB than the $900+ kit. And no trimming allowed on this one - Trail damage, okay, but no sawzall to the fenders, says she. What do you think of the front spring spacer and rear block lift? I don't want to do an add-a-leaf that will just flatten out, but she doesn't need a lot more articulation for where we usually go, and $$ is a big issue. A bit of tire rubbing at full stuff, no big deal.
Re: Time to Lift the Cherokee [Re: DBL_DTY97TJ] #929732 02/06/09 07:26 AM
4x4Wire Offline
I started with add-a-leafs and was not happy with them. Hence, the 4" springs form Tomken. And, the real fender trimming I did was to clean up damage from that time.
I am not a fan of blocks as they are unstable in off-camber/extreme articulation situations. That makes them dangerous to someone I really care about - ME.
I know people runs blocks in the rear on many vehicles. IMHO, they are unstable and not worth the risk of a shift under stress.
You could keep the stock coil springs and go with a 2" spacer up front. Then, you could spend the few bucks for the 4" rear springs.
You still need extended brake lines and a drop-transfer case.
I agree that a little rubbing isn't a big deal as long as it is not taking chunks out of the tire tread....
Go with the bigger leaf springs in the rear. It will save you time and money in the long run....
John Stewart
Editor - 4x4Voice
Re: Time to Lift the Cherokee [Re: 4x4Wire] #929733 02/06/09 10:39 PM
Thanks for the replies. 2" pucks up front is a definite. And thanks for the info about the blocks. I'm not understanding your 4" springs in the rear though. I don't think you mean 4" lift...Is it a 4" thick leaf spring pack?
Also, with 2" lift is the T-case drop & extended brake lines really necessary? I was under the impression this wasn't req'd if only lifting 2". Happy Friday! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Time to Lift the Cherokee [Re: DBL_DTY97TJ] #929734 02/06/09 11:35 PM
4x4Wire Offline
The leaf springs will give a lift depending on spring arch and length.
You buy leaf springs based on the amount of lift you desire.
I mean you need springs for a 4" lift. A 4" thick pack could give varying amount of lift... depending on length and arch.
Consider driveline angles....
Yes, when you start lifting a vehicle by suspension, you need to compensate by dropping the t-case. You should lonly need a 1/2 inch to 1" drop (spacer between the t-case mounting and frame).
You will be a lot happier with no driveline vibration to destroy u-joints....
John Stewart
Editor - 4x4Voice
Re: Time to Lift the Cherokee [Re: 4x4Wire] #929735 02/08/09 10:51 PM
Brown81CJ5 Offline
How about this kit? Comes with springs all around, and for less than $600 before shipping and taxes. RE Cherokee 3.5" lift
I know it doesn't come with shocks, but it seems like a pretty good deal to me.
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: Time to Lift the Cherokee [Re: Brown81CJ5] #929736 02/09/09 03:57 AM
4x4Wire Offline
Sure wished they had that when I was doing mine.....
That looks like a reasonable price kit....
John Stewart
Editor - 4x4Voice
Re: Time to Lift the Cherokee [Re: Brown81CJ5] #929737 02/10/09 12:08 AM
That is a nice one. If it was my Cherokee, I'd be going at least 3.5", but it's the GF's daily driver, drives clients around, etc. So I can't go too crazy. And the 2" should clear 31's except at full stuff, and that's as big as she's going to get. I'm not regearing this one. I would like to find a 2" that has a full rear spring pack though. And stay under $250. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Re: Time to Lift the Cherokee [Re: DBL_DTY97TJ] #929738 02/10/09 12:12 AM
Brown81CJ5 Offline
Good luck on that one. Have you checked ebay?
Gun it and run it!
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6456 MB (Peak: 0.7669 MB) Data Comp: Off Server Time: 2026-06-12 19:43:38 UTC
