Page 2 of 3 1 2 3
Re: HEADER FOR OUR MOTOR [Re: Everet] #929762 02/27/09 11:20 PM
DennisThompson Offline
Everet, Here are some pics of the factory Exhaust manifold from my 95. If you cut where my finger is on the third pic and weld on a header flange I think it will flow pretty good. The gasket where the down pipe bolts to the maniflod is already a standard header flange gasket. I would like to find an extra to try but save this one in case I mess it up <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />.
What do you think,
Dennis
Re: HEADER FOR OUR MOTOR [Re: 4runnernomore] #929763 02/28/09 12:43 AM
DEFBOY35 Offline
yeah dennis if you were to cut there and a nice clean collector 4 into 1 and then some slightly bigger exhaust back from there, it should work pretty good. i want one of those manifolds! that looks like it would be much better than the newer manifold set up
2000 SPORTY, DEF BOY customs, mmm....lockers, mmm... gears, mmm... double transfer case, mmm... stroker
http://www.cardomain.com/ride/2377991
Re: HEADER FOR OUR MOTOR [Re: DennisThompson] #929764 02/28/09 08:37 PM
Everet Offline OP
Dennis,
Didn't Flyboy do something like that to his exhaust?
4-1 gives you more top end hp. 4-2-1 will give you more bottom end torque and mid-range.
There are a few web sites that can help with lengths/sizes you might want to review because you get more torque with longer primary pipes usually.
Let me know how it goes!
Re: HEADER FOR OUR MOTOR [Re: Everet] #929765 03/01/09 06:41 AM
fokion Offline
are they interchangable????
meaning in my DOHC I can put te SOHC one??
Re: HEADER FOR OUR MOTOR [Re: fokion] #929766 03/11/09 07:22 AM
fokion Offline
Any update on this???
Re: HEADER FOR OUR MOTOR [Re: fokion] #929767 10/31/09 11:38 AM
2002_Sporty Offline
98 99 00 01 02 Kia Sportage Exhaust Manifold 58-906AB
US $115.00 2 available
http://cgi.ebay.com/ebaymotors/98-99-00-...202010006r12226
2002 4dr Kia Sportage 4X4
Tires:235/75/15, Wheels: Black 15x8 Steel ProComp 2.5" B.S., Hubs:Warn Manual, Lift:3" UPYOURKIA, Trailer Hitch, Cargo Rack, Clinometer.
Re: HEADER FOR OUR MOTOR [Re: 2002_Sporty] #929768 10/31/09 01:48 PM
minydigger Offline
I got one from the local PNP awhile back but havn't got around to doing it. Anyone have a source for a new collector?
Also is it stainless or what type metal is it.
Re: HEADER FOR OUR MOTOR [Re: minydigger] #929769 11/01/09 04:44 AM
Everet Offline OP
Factory tube exhaust is stainless.
In my 2000, I had a bad upper cat, so I hollowed it out and put it on. It really cut down on the bottom end torque. I believe with the reduced back pressure, the low rpm torque is adversely affected. Didn't notice any positive performance from the increased flow.
I am looking for a stock one like you got, put some longer runners on it and see if it improves the bottom end torque.
Keep us posted on your progress.
Re: HEADER FOR OUR MOTOR [Re: 2002_Sporty] #929770 11/01/09 04:53 PM
Axe Man Offline
Kia Moderator Emeritus
That is the factory exhaust manifold and it is cast iron, not stainless.
1998 Sportage - Gone.
2004 Honda Civic Coupe.
2007 Suzuki Grand Vitara - She got it.
Re: HEADER FOR OUR MOTOR [Re: Everet] #929771 11/01/09 04:55 PM
Axe Man Offline
See my previous post. Or are you referring to the 1995 header?
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6427 MB (Peak: 0.7524 MB) Data Comp: Off Server Time: 2026-06-09 18:21:06 UTC
