Page 3 of 3 1 2 3
Re: HEADER FOR OUR MOTOR [Re: Axe Man] #929772 11/01/09 09:05 PM
Everet Offline OP
I was referring to the 95-97 factory tube exhaust. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Looking at possibly making a tri-y-header to up the lower rpm torque.
Re: HEADER FOR OUR MOTOR [Re: Everet] #929773 11/01/09 09:33 PM
Hydra747 Offline
I know while I was looking into purchasing a new manifold (before Londart sold me his) That the 95-97 (NON-SOHC=DOHC) were way more costly then the cast types.
Was gonna go for this but I don't believe that little air flow change would make much of a difference.
Kinda like that cone filtr thing......Just makes you feel good inside.
I like the ones that Dennis took a pic of (SOHC)? Other is around.$260 'ish i believe.
I got the ones that FLY boy sold but it was not finished and honestly it was one of the poorest purchase decisions I have ever made. NObody's fault just a "project that failed."
I am very interested in HEADERS if they are available! <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: HEADER FOR OUR MOTOR [Re: Hydra747] #929774 11/02/09 05:08 PM
minydigger Offline
My stock manifold is cracked and in need of replacement before state inspection. Was looking for a solid replacement other than the stock style.
94 Zj custom suspension and other stuff
01 F250 tow hoe 5" exhaust
00'sporty 3" lift 235's
Re: HEADER FOR OUR MOTOR [Re: minydigger] #929775 11/03/09 01:41 AM
Hydra747 Offline
Do u mean that during inspection that they take off your heat sheild?
Or do you have a code on cluster screen?
Re: HEADER FOR OUR MOTOR [Re: Hydra747] #929776 11/03/09 04:07 AM
minydigger Offline
You can hear it under the hood.
Re: HEADER FOR OUR MOTOR [Re: minydigger] #929777 11/03/09 04:09 AM
6
69442 Offline
Ya, exhaust leaks suck donkey dukey <img src="/forums/images/graemlins/notooth.gif" alt="" />
LIFT OR BUST! 2001 Sportage EX 4dr 4WD with 300,210 miles & counting .....
____o_o
l_l_l\___\___
l----[o]==[o]
l----==[--]==
()_)()_)--()_)
Re: HEADER FOR OUR MOTOR [Re: 69442] #929778 11/03/09 08:49 AM
4
4runnernomore Offline
Guys,
HAve posted before on other threads about headers or extractors that are alreafdy made and available off the shelf.
Genie in Australia make a header or extractor for the Kia Sportage under the brand name of Wild cat.
KIA
SPORTAGE WILDCAT# 256
97-99 TRI-Y GASKET PRIMARY 2ND PIPE OUTLET MANUAL AUTO AIR-CON P/STEER OXY FITTING
MC SIZE SIZE FLANGE SENSOR TIME
2.0LTR NA 1 1/2" 1 3/4 2 Y Y Y Y Y 2hrs
**DIRECT BOLT-ON FITMENT
Here is a link
http://www.genieheaders.com/CATALOGUE%202009.html
Cheers, Chris
97 Sporty, snorkel, K&N filter,chipped, ext forks, 40mm Dob Springs, KYB struts, 35mm Jeep TJ Springs, RAV 4 OME shocks, Kaiser Locker 5.38 R&P's, 1&3/8 body lift, 245/75 R16 D674's Sports steering wheel, bullbar, extractors & 2 1/4 exhaust engineered.
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6235 MB (Peak: 0.7309 MB) Data Comp: Off Server Time: 2026-06-22 03:00:41 UTC
