Page 2 of 5 1 2 3 4 5
Re: 2" 4Crawler Body Lift Write up w/ Pictures [Re: 4ePajero] #929872 02/10/09 11:21 AM
DRaider90 Offline OP
Nice write-up.
Lifting the bumpers the same amount (as the body lift)looks so much nicer, and increases the approach angles by a small amount.
That is the next step, but Mark will have pictures of it done on his truck a good time before mine.
88 Raider(Red):160k-Reman'd 2.6-5spd-Weber-SW Hubs-34x9.5 TSL-OffRd Pkg-1"Tbar-2"BL-CB
88 Raider(Silver):No 2.6/Bad KM145 Parts/Project
88 Montero(Brown):No 2.6,4.88s Parts/Project
[b]4X4 STICKERS,SHIRTS,ETC:
4WD Stickers AT COST.[b]
Re: 2" 4Crawler Body Lift Write up w/ Pictures [Re: DRaider90] #929873 02/11/09 05:48 AM
motero Offline
If your lifting a 3.0 v6 gen I Montero, Don't forget the big bracket on top of the frame in the front of the rear wheel well.
99 Montero....15mpg! Sold (so sad)
02 Jetta TDI....48mpg!
03 2500 Ram QCLB Cummins....18mpg
02 2500 Yukon XL, We out grew the montero, at least it has one locker.....13mpg (sold)
01 montero limited
Re: 2" 4Crawler Body Lift Write up w/ Pictures [Re: DRaider90] #929874 05/19/09 08:09 PM
RALEX28 Offline
deleted the quote of the entire first post.
Re: 2" 4Crawler Body Lift Write up w/ Pictures [Re: RALEX28] #929875 05/19/09 09:05 PM
sparkem Offline
Uh yeah, we saw that in the original post.
Re: 2" 4Crawler Body Lift Write up w/ Pictures [Re: sparkem] #929876 05/19/09 11:54 PM
ghostraider Offline
my body does not have those two mounts in the rear of the vehicle!
but mine is a v6 5 spd. and not a 4 cyl.
<img src="/forums/images/graemlins/evil.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: 2" 4Crawler Body Lift Write up w/ Pictures [Re: ghostraider] #929877 05/20/09 12:22 AM
0778drz110 Offline
the v6 is different from the 2.6 so no worries <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 2" 4Crawler Body Lift Write up w/ Pictures [Re: sparkem] #929878 05/20/09 03:30 AM
K_Raider Offline
Saved me some time. <img src="/forums/images/graemlins/smile.gif" alt="" /> I was just getting ready to look for someone who did a body lift just to figure out how many and where the mounts are. I'm just about ready to start taking my Raider body off for the 350 and full size Chevy frame swap. <img src="/forums/images/graemlins/kewl.gif" alt="" />
88 Raider- sitting on a full size Chevy frame with 35.5x11.50x16 Dyna Torque II tractors
89 Montero- stock 2.6 M/T 30-9.50 BFG all terrains on American Racing Wheels
99 2500 Ram- 285-75-16 Uniroyal all terrains,straight pipes with no cat (yes its loud)
Re: 2" 4Crawler Body Lift Write up w/ Pictures [Re: DRaider90] #929879 05/20/09 04:50 AM
Nice work.
Leave the top shroud on. It helps...I think.
Recently did a 2" on the '95. It's much easier on a SWB.
Re: 2" 4Crawler Body Lift Write up w/ Pictures [Re: JohnnyBfromPeoria] #929880 05/20/09 01:16 PM
cdl1701 Offline
Nice write up Eli <img src="/forums/images/graemlins/kewl.gif" alt="" />
Could you have just raised the rear bumper and not needed to make those cut outs? Last time I looked at mine in the shop I don't thin I had those cut outs or blocks showing. Hmmm... now I am wondering if they even installed mounts in those locations <img src="/forums/images/graemlins/confused.gif" alt="" /> lol
88 Montero, 2.6 Black
Re: 2" 4Crawler Body Lift Write up w/ Pictures [Re: cdl1701] #929881 08/19/09 11:06 PM
If I remember correctly the bumper will fit over the lifted mounts in the rear, but I don't think it would mount back without some plates/modification. You may be able to drill new holes, but my memory is fuzzy on that.
Nice work.
Yeah I left the top shroud half on because it does help with air flow. I still at some point need to do the radiator drop so I can get the lower half of the shroud back on (if it is still laying around somewhere at Mark's house).
PHP: 7.4.33 Page Time: 0.016s Queries: 15 (0.011s) Memory: 0.6462 MB (Peak: 0.7543 MB) Data Comp: Off Server Time: 2026-11-02 03:00:16 UTC
