Page 4 of 10 1 2 3 4 5 6 … 9 10
Re: 1997 Montero LS 3.5 liter V6 Timing Belt change [Re: off-roader] #930144 02/07/11 08:15 PM
MCMILO Offline
I got PB for my car business so they will be up for a long time but if you want to host them elsewhere it's cool with me. As a stroke to my ego, you could credit me. smile
Here is the professionally made tool if you can find it.
Tool for holding the crankshaft pulley and holding the camshaft pulley.
No I do not know where to get it, sorry. cry
Here is you timing belt tensioner tool (find on ebay for less than $20)
Here's a How-to diagram for the tensioner.
Also....very cool for those pesky valve guide seals, a mitsubishi valve spring compressor and a link of where to buy. ($75....what a bargain)
http://www.euroexportinc.com/store/tools/mitsubishi-4g63-valve-spring-compressor.html
MORE TO COME... <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 1997 Montero LS 3.5 liter V6 Timing Belt change [Re: MCMILO] #930145 02/11/11 12:06 AM
MCMILO Offline
Okay..now another problem. The crankshaft pulley is stuck. I've soaked it with WD40 for 2 days and used a half can of CRC Freeze Off so far today.
The 3 arm puller is as tight as I can get it and it's center "push" bolt is bending from the pressure. I actually had to use my holder bar to keep from rotating the motor.
Any ideas? <img src="/forums/images/graemlins/baby.gif" alt="" />
Re: 1997 Montero LS 3.5 liter V6 Timing Belt change [Re: MCMILO] #930146 02/11/11 12:33 AM
WD40 should not be used as a penetrating oil to loosen bolts. It's primary use is to displace water.
I'd start by using a proper penetrating oil. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 1997 Montero LS 3.5 liter V6 Timing Belt change [Re: off-roader] #930147 02/11/11 01:08 AM
If you used a puller on it, the pulley is now dead, due to broken adhere on the rubber insert, so cut it off. May have the same problem with the timing belt sprocket, but they are powdered metal and can be drilled and split off.
PB Blaster is a very good penetrant, as is Mouse Milk. Try some sharp blows to the pulley near the center...
Re: 1997 Montero LS 3.5 liter V6 Timing Belt change [Re: off-roader] #930148 02/11/11 01:19 AM
MCMILO Offline
I know, hence the name WD. That's why I'm using CRC Freeze off, it IS a penetrant.
Re: 1997 Montero LS 3.5 liter V6 Timing Belt change [Re: fasteddy] #930149 02/11/11 01:25 AM
MCMILO Offline
Not sure what you mean about "dead", the pulley isn't deformed and hasn't moved...it's still stuck to the TB sprocket as far as I can tell. I'm not cutting anything off right now but thanks for another "short-cut".
I'm looking for some ideas as to something I may be missing in the removal process or is this common for it to stick like this?
Re: 1997 Montero LS 3.5 liter V6 Timing Belt change [Re: MCMILO] #930150 02/11/11 01:33 AM
Usual to stick. Reinstall with anti seize.
Re: 1997 Montero LS 3.5 liter V6 Timing Belt change [Re: fasteddy] #930151 02/11/11 02:00 AM
MCMILO Offline
Re: 1997 Montero LS 3.5 liter V6 Timing Belt change [Re: MCMILO] #930152 02/11/11 02:29 PM
I made my tool with the swing arm design. I can use it for cam gears as well.
How s the CRC compared to Blaster? I'd spray liberally with PB, especially inside there. Then tappity-tap the pulley in from the front and around where it's stuck. Reach in there with a big drift maybe.
Funny how yours is stuck. I have done three now up here in the heart of the rust belt and not had that problem.
Re: 1997 Montero LS 3.5 liter V6 Timing Belt change [Re: MontyMcV] #930153 02/11/11 03:51 PM
Mad_Scientist Offline
I have used a puller on mine before. It did not damage the pulley, but the crank sprocket was stuck to the pulley. You then run the risk of destroying the crank sensor. I got lucky. I had to use some gentle heat to get the two apart. Mud was the culprit.
Eddy, does the Gen2 pulley have a rubber insert?
PHP: 7.4.33 Page Time: 0.082s Queries: 15 (0.078s) Memory: 0.6478 MB (Peak: 0.7577 MB) Data Comp: Off Server Time: 2026-10-31 21:03:15 UTC
