Page 6 of 10 1 2 … 4 5 6 7 8 9 10
Re: 1997 Montero LS 3.5 liter V6 Timing Belt change [Re: Clem1] #930164 05/26/12 06:29 AM
MCMILO Offline
Here's a trivia question concerning the timing belt tensioner pulley, do the 2 holes go above or below the bolt? I've seen both ways in the service manuals but no one ever says anything about it. <img src="/forums/images/graemlins/confused.gif" alt="" />
OR
Re: 1997 Montero LS 3.5 liter V6 Timing Belt change [Re: MCMILO] #930165 05/26/12 04:46 PM
hazy_daze Offline
It's a cammed bolt, it'll find its home with proper torque. Gravity will drop it to the bottom of range, then it'll wind around when you get to torque. It's not a specific position is what I'm trying to say...
Re: 1997 Montero LS 3.5 liter V6 Timing Belt change [Re: hazy_daze] #930166 05/26/12 11:42 PM
MCMILO Offline
That makes no sense. The holes are either on top or on bottom BEFORE you tension the pulley. Do you tension it clockwise or counter-clockwise. It doesn't "do it by itself". If you look at the pictures, in one it shows you push DOWN to tension, in the other it shows you tension UP.
Sounds like you don't know either.
Re: 1997 Montero LS 3.5 liter V6 Timing Belt change [Re: MCMILO] #930167 05/28/12 04:46 AM
justice Offline
Good catch. Enlighten us.
Re: 1997 Montero LS 3.5 liter V6 Timing Belt change [Re: MCMILO] #930168 05/28/12 01:55 PM
hazy_daze Offline
Gosh, I've only done it like 30 times or so, with 0 failures. Guess I really don't know.
Anyhoo. If you look at the pictures, it's a cammed center. Kind of like alignment cams on the rear of a FWD vehicle. If you rotate it towards the belt in a clockwise direction, it'll create tension. When you reach the torque spec, lock it down. Done. Top or bottom doesn't matter. It will find its home with torque. Perhaps that's clearer? If not, perhaps Eddie can translate this for you. I think he's still fluent in Alabamanese... <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: 1997 Montero LS 3.5 liter V6 Timing Belt change [Re: hazy_daze] #930169 05/29/12 06:50 PM
MCMILO Offline
The question was where the holes were supposed to be, on top or bottom but you didn't say. Nor did you say clockwise, which I asked. And it DOESN'T just "find it's place". Perhaps if you spent more time being CLEAR in answering a question the first time then the sarcasm wouldn't have blown out your ass.
Thank you for being clearer on your second response. Perhaps even saying "it doesn't matter top or bottom will work" would have served as well.
And just because you've done it 30 times doesn't mean a fart if you can't communicate directions properly.
Re: 1997 Montero LS 3.5 liter V6 Timing Belt change [Re: MCMILO] #930170 05/29/12 07:49 PM
I speak NORTH Alabamanese. I have trouble understanding people from Mobile - too much French influence, which may expain the rudeness...
Re: 1997 Montero LS 3.5 liter V6 Timing Belt change [Re: MCMILO] #930171 05/29/12 08:00 PM
That makes no sense...
I know you're probably frustrated but perhaps instead of trying to call him out just because you didn't understand you'd be better served by simply asking if he can explain it better much like Justice did? <img src="/forums/images/graemlins/wink.gif" alt="" />
That's usually worked better for me anyways although I must admit I haven't always handled things that way. <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
HTH
Re: 1997 Montero LS 3.5 liter V6 Timing Belt change [Re: MCMILO] #930172 05/29/12 08:25 PM
That will go a good ways to getting sound advice from the long-timers here... <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Re: 1997 Montero LS 3.5 liter V6 Timing Belt change [Re: MontyMcV] #930173 05/30/12 01:41 AM
hazy_daze Offline
Um ok. Sorry if I wasn't real clear in my first reply. I was at work and in a hurry to try to help you out. That's why my last was "I hope that makes sense" or some such. I understand being frustrated with a certain part of a project and not getting an answer that makes sense to YOU, no matter who else it makes sense too. A saying goes "One hasn't taught until someone has learned." My apologies for not being clear in the first reply. And I'm sorry for the sarcastic start to my second reply. I'm an idiot and I truly have no sense of cooth or manners... Hope you've got it licked and it's smooth sailin' from here <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.014s Queries: 16 (0.010s) Memory: 0.6501 MB (Peak: 0.7754 MB) Data Comp: Off Server Time: 2026-11-02 09:02:22 UTC
