Page 2 of 10 1 2 3 4 9 10
Re: 1997 Montero LS 3.5 liter V6 Timming Belt change [Re: MCMILO] #930124 02/04/11 10:33 PM
I never used the pulley tool, just put the breaker bar handle on the frame rail and bump the starter a noodge, then rednek torque the bolt back on with a dead blow hammer. Never had one come loose. Tool is a pretty easy fab, though...
Re: 1997 Montero LS 3.5 liter V6 Timming Belt change [Re: fasteddy] #930125 02/05/11 07:04 PM
MCMILO Offline
Um...yeah, thanks but I'm not taking short-cuts and risk breaking things that aren't broken, ya know? Also, I have a torque wrench and I'm meticulous when it comes to specs. So I'm making the tool.
Re: 1997 Montero LS 3.5 liter V6 Timming Belt change [Re: MCMILO] #930126 02/05/11 07:11 PM
mxmikie Offline
Um...yeah, thanks but I'm not taking short-cuts and risk breaking things that aren't broken, ya know? Also, I have a torque wrench and I'm meticulous when it comes to specs. So I'm making the tool. [/quote]i want to borrow it
Re: 1997 Montero LS 3.5 liter V6 Timming Belt change [Re: mxmikie] #930127 02/05/11 07:41 PM
I recommend your choice, but I've actually tested mine. I had a dial type snapon torque wrench, a goodun', and I tightened it and then tested the release torque with the wrench several times. Got pretty close, within less than 10ftlbs every time. But then I've got an edjicated dead blow hammer, with smart shot inside...
If I had the tool, I'd use it. I'd still loosen it my way. Too easy...
Re: 1997 Montero LS 3.5 liter V6 Timming Belt change [Re: MCMILO] #930128 02/06/11 04:23 AM
Happy Birthday hazy_daze Offline
Good call. I wouldn't listen to Eddy either. He's an idiot.
Re: 1997 Montero LS 3.5 liter V6 Timming Belt change [Re: hazy_daze] #930129 02/06/11 06:32 AM
haztoys Offline
LOL... Your killing me Hazy that was a good one.. <img src="/forums/images/graemlins/lol.gif" alt="" />...As we all know by reading Eddys post he's forgot more about motors then most will ever know ..
Buy a chain wrench for the HB you can use it for other things too...
Re: 1997 Montero LS 3.5 liter V6 Timming Belt change [Re: haztoys] #930130 02/06/11 07:27 AM
I'm not and idiot, I just spawned and idiot detector, WWFF. If I was an idiot, why would I hang around here. No, wait, don't answer that... <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: 1997 Montero LS 3.5 liter V6 Timming Belt change [Re: fasteddy] #930131 02/06/11 02:55 PM
mxmikie Offline
Re: 1997 Montero LS 3.5 liter V6 Timing Belt change [Re: mxmikie] #930132 02/06/11 06:18 PM
Kevin C Offline
He still dresses the same.... At least when he's out on a date.
Re: 1997 Montero LS 3.5 liter V6 Timing Belt change [Re: Kevin C] #930133 02/07/11 12:26 AM
No, actually in my early years I was Ilya Kuryakin...
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6452 MB (Peak: 0.7535 MB) Data Comp: Off Server Time: 2026-06-23 22:31:37 UTC
