22r fuel pump leaks out weep hole #930559 02/10/09 11:21 PM
1
1984NCYota Offline OP
Would the fuel pump be or the vent plugged? It runs great just leaks gas out of the weep hole.
If pump, what are good pumps? Would the autozone, napa, or chain store pumps do ok. Napa has an airtex for $37. Is it ok?
Thanks
1984 X-cab 4x4, chevy one wire alternator, 22r, looking for mods
Re: 22r fuel pump leaks out weep hole [Re: 1984NCYota] #930560 02/11/09 03:22 AM
kewlynx Offline
If that's the original, it's time to move on. I've used NAPA pumps with no issues.
**ubi apis- ibi salus**
Re: 22r fuel pump leaks out weep hole [Re: 1984NCYota] #930561 02/11/09 06:28 AM
yota4runna Offline
Good thing you saw it leak to the outside. They can leak to the inside and fill your crankcase with gas, diluting the oil. Bad for engine bearings.
Re: 22r fuel pump leaks out weep hole [Re: yota4runna] #930562 02/11/09 06:31 AM
kewlynx Offline
It's called 'washdown'- a bad AAP pump on a carbie will do this also- Toy trivia for the day. <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5985 MB (Peak: 0.6537 MB) Data Comp: Off Server Time: 2026-06-20 06:29:58 UTC
