Page 3 of 3 1 2 3
Re: Please help quick! I'm kinda panicking here... [Re: ForcedAir_Montero] #930760 02/18/09 03:05 AM
grass13 Offline
This is petroleum in nature. Kinda smells like gear oil. Old nasty gear oil.
Any other ideas? I'm all ears <img src="/forums/images/graemlins/kewl.gif" alt="" />
where do your diff breather hoses go to? when was the last time you changed your diff oil, much less pack the axle bearings? i know the kiwi didnt get out much until you moved, but mabey that long drive you were so worried about finnally caught up with your running gear. imho, if it smells like burnt gear oil... it probably is.
btw, i know it sucks with the stink of the tacoma aroma seeping into the kiwi... but i hope everything else is allgood. drop me a line.
ps, if your still selling it... ill boost my last offer with additional 12pk of bud.
Re: Please help quick! I'm kinda panicking here... [Re: grass13] #930761 02/18/09 04:09 AM
If something is hot enough to vaporize/burn gear oil, it will be HOT to the touch. Take a ground cloth with you, drive until it smells strong, crawl under, and feel the diffs, tcase, tranny, axles...
Most gear oils have castor oil in them. Have you ever smelled straight castor oil? Note that breathing vaporized castor oil fumes will give you the galloping trots...
Re: Please help quick! I'm kinda panicking here... [Re: fasteddy] #930762 02/18/09 08:42 PM
dadrab Offline
Gear oil is the stink that keeps on giving...
I've had such a stench under the hood of my truck ever since I did the engine swap. I never smell it in the truck, but every now and again, I'll smell it with the hood down - and always with it up.
Like you, I can't figure for the life of me where it comes from. I've changed the oil in the diff, t-case and tranny. There appeared to be none missing from any of the above, so I'll be damned if I can tell where the smell's coming from, but it's always there.
My truck's my DD now too and it runs fine. It just smells when I raise the hood.
My only theory is that perhaps I have a small leak somewhere that puts a drop on or near my turbo. I run synthetic oil, and the smell of it burning is pretty fowl.
I don't burn any oil and there's no smoke from the tailpipe. After my experiences with spinning the turbo shaft nut and dumping oil in the turbo, I know what to expect if that circlip (seal) at the back of the shaft goes south. You'll look like the mosquito fogging machines of old rolling down the highway. There will be no doubt in your mind what's going on in that regard.
with awesome audio.
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6019 MB (Peak: 0.6717 MB) Data Comp: Off Server Time: 2026-11-03 09:22:36 UTC
