Page 12 of 12 1 2 … 10 11 12
Re: Hopefully a New Addition to the Firearms Collection [Re: Grasscat] #931241 05/04/09 05:09 PM
FrankR Offline OP
Sure would, but it won't fit in the center console (legally).
My lower back is now killing me and I can barely walk. I'm beginning to think I already had a lower back strain when I went to the range, but the joint pain hadn't yet made itself felt. That COULD have caused the barrel movement. Since I don't want to gobble painkillers and visit the range, I'll wait until this mess is over with to go back and see if I get different results....... weird.
Frank
Re: Hopefully a New Addition to the Firearms Collection [Re: FrankR] #931242 05/05/09 12:04 AM
FrankR Offline OP
I think I figured it out - the back strain is from driving the Mighty Max with no power steering, M/T and two sagging worn out seats (mine and the truck's):
I pulled the split bench/buckets out of a Ranger and will see if I can adapt them to the MM - then try the range again after I recuperate....... owwwweeeee! <img src="/forums/images/graemlins/shiner.gif" alt="" />
Frank
Re: Hopefully a New Addition to the Firearms Collection [Re: FrankR] #931243 05/05/09 12:48 AM
Grasscat Offline
It's tough getting old Frank.
But if you keep moving the grim reaper will pass you by. <img src="/forums/images/graemlins/smile.gif" alt="" />
Michael j
TreadLightly! Trainer
Re: Hopefully a New Addition to the Firearms Collection [Re: FrankR] #931244 05/05/09 01:56 AM
holger Offline
These seats are asking for the joints disaster... you are a tough guy if you are able to survive these seats in your age. But I'd suggest fixing them.
Oleg
Deceased Rodeo'02 4WD.
Re: Hopefully a New Addition to the Firearms Collection [Re: holger] #931245 05/05/09 02:58 AM
Heat! More heat!! Burn out the pain...
Voice of exasperance (don't tell me there's no such word. has to be one) speaking. Bet those seats made you hang on your left cheek, betcha. You've got uneven assitis. It will pass with enough heat and tablets. I recommend aspirin.
In my limited experience, I got the best groups out of a .45 single handed (I've always been better that way for some odd reason) is to actually grip the gun with the first joints of the thumb and index, with only a light wrap with the fingers, tight in the web, trigger in the last index joint. The little finger almost floats on the grips.
You know what those groups of yours look like to me?
Dead men. Sufficient.
PHP: 7.4.33 Page Time: 0.014s Queries: 16 (0.010s) Memory: 0.6212 MB (Peak: 0.7019 MB) Data Comp: Off Server Time: 2026-11-13 06:37:17 UTC
