#4 plug stuck... thread skipping on removal #931857 02/19/09 07:10 AM
Crops Offline OP
A great couple months for me -- I swear I could start like 20 threads on my issues. Immediate problem:
My 89 V6 SWB raider is in the shop (A mitsu dealership with a rather new and fairly decent and earnest service crew). Crazy rough running engine led them to a particular plug that was not working and I have opted to get all new Plugs and wires done while there.... problem -- seems my #4 plug is stuck. As they try to remove it they can feel it thread skipping/slipping. They are worried about two things: 1 -- is it sealed or will it leak at this point? (giving them the option of leaving it in if it is working and sealing). #2 -- if they remove it there may be a rather expensive thread repair on the head -- apparently #4 position is awkwardly situated so hard to service and work on -- a head repair would be expensive and difficult.
This is my paraphrase of what they have told me so there might be some slight inaccuracies -- they want to know what to do -- what I want them to do. Anyone here familiar with this issue? Any tricks on getting that plug out without head damage. Any tricks on working on that particular head/position? I'm not sure what to do -- they are waiting on my call.
Many thanks for any thoughts/suggestions.
R.
89 Raider V6
95 SR Montero
Re: #4 plug stuck... thread skipping on removal [Re: Crops] #931858 02/19/09 07:24 AM
LandRaider Offline
Remove old plug, and install a Helicoil. Problem solved.
Re: #4 plug stuck... thread skipping on removal [Re: LandRaider] #931859 02/19/09 02:06 PM
Tag Offline
I bet they would not be willing to do that at a dealership.
89 2dr 3.0 AT, manual hubs. 33x12.5 MT
gen 2 coils,Cranked front tbars
Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
Re: #4 plug stuck... thread skipping on removal [Re: Tag] #931860 02/19/09 05:13 PM
V
vr4 Offline
no helicoil on spark plugs. they dont seal properly.
there are inserts available (plug blowout is a common problem on the ford mod V8) and we install inserts (with no warranty) all the time at the dealer.
87 Montero V6 SWB auto. dual bouncies
89 Montero V6 SWB 5 speed. dual bouncies
97 3000gt VR4 upgraded turbos, 10:1, E85
91 Stealth TT twin 18Gs, cams/heads, E85
03 cobra lightly modded <img src="/forums/images/graemlins/lol.gif" alt="" />
91 MR2 turbo
Re: #4 plug stuck... thread skipping on removal [Re: vr4] #931861 02/19/09 06:22 PM
Crops Offline OP
Thanks for your input guys. No matter how I look at this I guess it's not a great situation.
89 Raider V6
95 SR Montero
Re: #4 plug stuck... thread skipping on removal [Re: Crops] #931862 02/19/09 07:46 PM
joestruck Offline
JB weld and duct tape?
Re: #4 plug stuck... thread skipping on removal [Re: joestruck] #931863 02/19/09 10:34 PM
Don't forget bubble gum and pop tarts. <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Re: #4 plug stuck... thread skipping on removal [Re: rxinhed] #931864 02/20/09 01:39 AM
LandRaider Offline
My BBC GM Performance Parts Aluminum heads came from the factory with Helicoils in them. <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: #4 plug stuck... thread skipping on removal [Re: LandRaider] #931865 02/20/09 09:32 PM
Tag Offline
In that case you can just ship that whole pos motor to me and I will get rid of it for you. <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: #4 plug stuck... thread skipping on removal [Re: LandRaider] #931866 02/20/09 11:59 PM
V
vr4 Offline
while this picture isnt 100% accurate.....it is a good picture of the insert (the lower 1) we use at the dealer.
http://www.denlorstools.com/autoblo...oil-look-at-calvans-ford-spark-plug-kit/
the picture isnt 100% accurate though. hes not holding the actual helicoil spark plug insert. just a standard helicoil.
having seen them side by side and used them i would never use the helicoil brand insert again. we actually had a truck come in about a month ago with the helicoil insert blown out.
this is the actual helicoil insert.....
91 MR2 turbo
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.005s) Memory: 0.6460 MB (Peak: 0.7661 MB) Data Comp: Off Server Time: 2026-06-23 03:55:37 UTC
