What's My Oil Pressure - Real Pressure #932598 02/22/09 01:25 PM
tdf_46 Offline OP
I have a Gen1 with the 3.0 and my Oil Pressure Gauge shows only about 20# at highway speeds and near 0# while idling.
Hummmm....that doesn't seem like a good thing! My engine seems to run fine. Except for a sticky valve lash adjuster that is intermitent, there is no mechanical indication that it is stressed or over heating in any way.
But before I start pulling the engine to replace the oil pump and/or measure bearing tolerances for wear (yes it has a bunch of miles on it), I thought I would connect one of my after market oil pressure gauges up and have a 2nd reading to verify the pressure is actually low (not just a faulty gauge). I already replaced the send unit (no change).
Here is the issue: All my gauges are US Meas. (likely pipe thread) close but not correct for the oil pressure port.
Can anyone point me to a source for a metric adapter. Tried a good hardware store and auto parts store. No GOT!
Thanks
tdf_46 (Tom)
Re: What's My Oil Pressure - Real Pressure [Re: tdf_46] #932599 02/22/09 06:19 PM
Hans_GZP Offline
You need a BSPT to NPT adapter. Autometer carries them.
My oil pressure on my 3.5 dohc is around 12 psi at hot idle and about 60 psi around 3000 rpms.
96 Montero SR
94 Dodge Stealth TT
92 Mitsu Galant VR4
91 Mitsu 3000GT
95 Mitsu 3000GT, carbon black, for sale
95 Mitsu 3000GT, white, for sale
92 Mitsu 3000GT VR4, silver, for sale
Re: What's My Oil Pressure - Real Pressure [Re: Hans_GZP] #932600 02/22/09 08:10 PM
BSPT to NPT adapter
Or just use an 1/8"npt tap to ream the BSPT threads a touch so the NPT sender threads will start. It's a tpaer thread and the pitch is VERY close, so your new BSPT sender will still fit. Or you could get an NPT die and turn the taper on the npt fitting down a tad for the same effect. It's how I fitted my autometer fitting on the 2.6T.
Re: What's My Oil Pressure - Real Pressure [Re: fasteddy] #932601 02/23/09 12:49 AM
tdf_46 Offline OP
Hans & Fasteddy,
Both good tips for me!
I knew the fit was close but you can't get the threads started as you have said Fasteddy!
Thanks!
tdf_46 (Tom)
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6012 MB (Peak: 0.6578 MB) Data Comp: Off Server Time: 2026-06-17 15:07:50 UTC
