Re: '99 XJ Oil Gauge [Re: BigJim] #933000 03/01/09 07:20 PM
Bigbird79 Offline OP
[quote/] Most modern gauges are simply glorified lights! When 12 pounds or so are reached the needle goes to the MIDDLE of the gauge. Then when the pressure drops to 12 pounds or less the needle goes to the bottom..
[/quote]
If that was true and the gauge was just going to some pre-specified mid location, then I would not expect the gauge to ever move with engine speed. I don't doubt they do use gauges like that in place of idiot lights in some vehicles, but I have to believe if the gauge is moving with engine speed, then it has to actually be reading oil pressure. If I had my way, and it wasn't my daily driver that I wanted to keep clean, I would have all mechanical gauges.
Just my 2 cents.
Sean
99 XJ Sport 2 Door, 4.0L, 5 speed, all stock. Daily Driver
79 F150 Standard Cab Short Box, 400ci, NP435, NP205, 35" SSRs
Re: '99 XJ Oil Gauge [Re: Bigbird79] #933001 03/01/09 09:18 PM
DBL_DTY97TJ Offline
There is no way to trend a failed light bulb.
<img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> So true.
Thanks for the replies, BJ & Sean.
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5921 MB (Peak: 0.6410 MB) Data Comp: Off Server Time: 2026-06-07 00:28:38 UTC
