Anyone know the specs of a 9" diff #933055 02/24/09 08:32 PM
CraShYota Offline OP
I need to know the distance on the third member chunk between the plane which gets mounted to the face of the axle housing to the center of the carrier.
Anyone? Or any ideas of where to find this info? I have a 9" diff but i don't have the carrier. I estimate its a little over 1.5" but id like the exact number if anyone knows it.
Thanks.
Welding and Fabrication Engineer
2003 taco V6 ext cab sr5
1988 Toyota Pickup V6(totaled)
Re: Anyone know the specs of a 9" diff [Re: CraShYota] #933056 02/24/09 09:45 PM
sparkem Offline
Ford 9in? Mitsu 9in?
Re: Anyone know the specs of a 9" diff [Re: sparkem] #933057 02/24/09 11:07 PM
ford 9". sorry i didn't know there was another 9".
Re: Anyone know the specs of a 9" diff [Re: CraShYota] #933058 02/25/09 12:52 AM
sparkem Offline
That is what I figured, but if it was a Mitsu one I could get a measurement for you.
Re: Anyone know the specs of a 9" diff [Re: sparkem] #933059 02/25/09 01:39 AM
I measured it as 1 23/32". but i measured assuming that where the chunk splits to hold the carrier is halfway and therefore the center. Hope its right. I'm designing/building a 9/60 moly housing. this may end up being the worst ***** show in the world. lmao. if there is a gap just fill it with weld right?
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6048 MB (Peak: 0.6688 MB) Data Comp: Off Server Time: 2026-11-04 09:37:48 UTC
