Page 1 of 3 1 2 3
Parts Search: any resolve?? #933176 02/25/09 03:15 AM
Scottie2113 Offline OP
I am in search of a new coolant outlet fitting for the 3.5L SOHC Engine on a 99 Montero. Dealers everywhere say it is not available anymore. Has anyone got a way to get parts that dealers say are not around anymore? The part number is: MD332667 Any help would be greatly appreciated. Thanks.
97 Montero SR w/Mitsu Adj Shocks & Rear Diff Lock ARB Front Diff Lock 4.9 Ring/Pinion 3.15 transfer box 43:1 crawl ratio 2" suspen lift 2" body lift 2" Gas Tank Lift 35x12.5 MTRs 15x10 Wheels Rock Sliderz ARB front bumper w/12k winch Custom rear bumper
Re: Parts Search: any resolve?? [Re: Scottie2113] #933177 02/25/09 03:32 AM
I'm going yarding tomorrow, rain or sun. I'll look around for you. Are the 3.5L pieces the same all years??
Re: Parts Search: any resolve?? [Re: rxinhed] #933178 02/25/09 04:01 AM
not totally sure if they are all the same, I would think the 97-00 monteros all had this same part; mine is a 99. it has two different temperature sensors screwed into it. the fitting has 3 openings, one that uses an O ring that connects to a solid metal pipe that goes towards the rear of the engine, the other opening is out the bottom down to the t-stat housing, and the third opening is the upper radiator hose connection.
thanks for any help.
any other sources are welcome, new or used.
Re: Parts Search: any resolve?? [Re: Scottie2113] #933179 02/25/09 04:12 AM
what I don't understand is, car companies always talk up how wonderful their product is and how it will last you for a long time and has longevity, but how can one keep a vehicle well maintained if they stop making parts for them? I know this vehicle is now 10 years old, but wasn't it designed to last a long time? why would you stop making parts for it after only 6 years??? It only has 80k miles on it and has many more miles left in it.
there has to be a source or a way to get parts from overseas. someone has got to have a hook up somehow. we have folks on here in different countries, can anyone get that part (part number above) from an international source?
Re: Parts Search: any resolve?? [Re: Scottie2113] #933180 02/25/09 12:46 PM
lordtrunks Offline
scott i'll be talking with a dealer in Oz this month or start of next month they have more parts avalible still cause pajeros are more common there, i have a speedo gear i need to order to adjust for my 35's and can't get it here anymore.
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: Parts Search: any resolve?? [Re: lordtrunks] #933181 02/25/09 02:01 PM
Mad_Scientist Offline
I should be down the yard on Saturday. I'll look to see if that part is still on the '98
Re: Parts Search: any resolve?? [Re: Mad_Scientist] #933182 02/25/09 02:02 PM
mitsubishiparts.net claim to have that p/n available. $71 <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: Parts Search: any resolve?? [Re: Mad_Scientist] #933183 02/25/09 03:41 PM
yeah, I am not worried about price, but even though they have some parts listed, I called them and they can't get it. Any sources are welcome, I will pay whatever is required and if more than one source comes through with the part, I don't mind getting 2 or 3 just to have and since folks are helping out.
thanks a bunch guys.
also, if getting from a part yard, if possible please get the bleed bolt and the bolt that holds the wiring harness brackets on top of the engine. it is a 12mm hex head.
Re: Parts Search: any resolve?? [Re: Scottie2113] #933184 02/25/09 05:20 PM
V
vr4 Offline
if its interchangable with a diamante 3.5 sohc (doubt it) i have 2
87 Montero V6 SWB auto. dual bouncies
89 Montero V6 SWB 5 speed. dual bouncies
97 3000gt VR4 upgraded turbos, 10:1, E85
91 Stealth TT twin 18Gs, cams/heads, E85
03 cobra lightly modded <img src="/forums/images/graemlins/lol.gif" alt="" />
91 MR2 turbo
Re: Parts Search: any resolve?? [Re: vr4] #933185 02/25/09 08:00 PM
do you have a VIN? I will cross check the part number.
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 1.869s Queries: 16 (0.007s) Memory: 0.6443 MB (Peak: 0.7679 MB) Data Comp: Off Server Time: 2026-11-14 16:15:28 UTC
