still no spark
#933424
02/27/09 09:08 AM
ive replaced the ignition control module, and the coil pack and i still have no spark on my 91.
what else could i be over looking?
Re: still no spark
[Re: PatrickS]
#933426
02/27/09 02:25 PM
There is a sensor in the distributor that will stop spark.
Re: still no spark
[Re: sparkem]
#933427
02/27/09 03:16 PM
No sage advice to offer here. But, I do have a manual for 1989 Raider Powertrain Diagnostic Procedures (Includes: No-start and Driveability)
(Follow linky in my sig...)
Re: still no spark
[Re: 91monterov6]
#933428
02/27/09 05:39 PM
Have you given the ECU a sniff?
Re: still no spark
[Re: hazy_daze]
#933429
02/27/09 06:44 PM
Have you given the ECU a sniff? agreed. smell for a rotten fish smell. i just fixed 1 locally that was getting no spark. pull dist and spin it and no spark. ground the PTU and get spark. slap in known good ecu and gets spark and fuel pulse. i think i have a couple ecus for a 91 lying around.....
87 Montero V6 SWB auto. dual bouncies 89 Montero V6 SWB 5 speed. dual bouncies 97 3000gt VR4 upgraded turbos, 10:1, E85 91 Stealth TT twin 18Gs, cams/heads, E85 03 cobra lightly modded <img src="/forums/images/graemlins/lol.gif" alt="" /> 91 MR2 turbo
Re: still no spark
[Re: sparkem]
#933430
02/27/09 09:35 PM
There is a sensor in the distributor that will stop spark. I think the angle sensor come with a new distributor. But i would check the ecm or for a fried wire.
93 montero sr 3 inch body lift 31x11.50 super swamper ltb, 2 8inch 130 watt pro comp off road lights, 2 55w lights on the rear bumper, rear air locker, magnaflow exhaust muffler,superwinch manual hubs,15x8 black rock crawlers (steel)
Re: still no spark
[Re: sparkem]
#933431
02/28/09 07:55 AM
There is a sensor in the distributor that will stop spark. It is an optical sensor and was my problem.
89 3.0 LWB Montero, 1st Gen, 5 Speed Manual, 5 Door
Re: still no spark
[Re: vr4]
#933432
02/28/09 11:13 AM
Have you given the ECU a sniff? agreed. smell for a rotten fish smell. i just fixed 1 locally that was getting no spark. pull dist and spin it and no spark. ground the PTU and get spark. slap in known good ecu and gets spark and fuel pulse. i think i have a couple ecus for a 91 lying around..... im going to pull the ecu and check it again... one note, when i crank her the ecu clicks alot. how much you charging for one of those ecu's?
Re: still no spark
[Re: MontyMcV]
#933433
02/28/09 11:15 AM
(Follow linky in my sig...) lol i practically got the manual memorized
