Re: still no spark
[Re: 91monterov6]
#933434
02/28/09 01:46 PM
one note, when i crank her the ecu clicks alot. There is an ECU relay located in same area as ECU. Could be your problem and not the ECU. I hear mine click after a short delay when I shut the engine off. I don't hear any click at start-up, probably just due to engine/starter noise.
Re: still no spark
[Re: pcc]
#933435
03/01/09 01:53 AM
dave h. '89 Raider V6 5spd;Aisin Hubs;; Gen2 LS: frt. brakes, rear coils;U.C.arms;R.trailing arms;idler arm; rear LSD axle w.disc brakes ;2 battery system for Dog's fan; relocated ECU; custom bumpers;J.Baker receiver;Conferr roofrack; t-bar crank.
Re: still no spark
[Re: 91monterov6]
#933436
03/01/09 02:00 AM
im going to pull the ecu and check it again... one note, when i crank her the ecu clicks alot.
how much you charging for one of those ecu's?
make a resonable offer. ill open it up and double check it for damage. i dont think it had any leaking caps when i checked it last time.
87 Montero V6 SWB auto. dual bouncies 89 Montero V6 SWB 5 speed. dual bouncies 97 3000gt VR4 upgraded turbos, 10:1, E85 91 Stealth TT twin 18Gs, cams/heads, E85 03 cobra lightly modded <img src="/forums/images/graemlins/lol.gif" alt="" /> 91 MR2 turbo
Re: still no spark
[Re: vr4]
#933437
03/01/09 07:14 AM
Re: still no spark
[Re: 91monterov6]
#933438
03/01/09 07:16 AM
also i have an aqua blue buildup on my ecu's harness plug pins..... i cleaned it off, still no go
Re: still no spark
[Re: 91monterov6]
#933439
03/01/09 07:53 AM
That aqua blue buildup is oxidized copper. You can usually take it off with a pen eraser (has abrassives in it) if you can reach it. You may need to cut the eraser to make it reach.
Re: still no spark
[Re: 91monterov6]
#933440
03/01/09 01:26 PM
also i have an aqua blue buildup on my ecu's harness plug pins..... i cleaned it off, still no go Radio Shack's "Control/Contact Cleaner & Lubricant" #64-4315 does a good job at cleaning electrical contacts. Also CRC "QD Electronic Cleaner" #05102. Will also get inside the female harness as well.
Re: still no spark
[Re: pcc]
#933441
03/01/09 04:03 PM
Radio Shack's "Control/Contact Cleaner & Lubricant" #64-4315 does a good job at cleaning electrical contacts. Also CRC "QD Electronic Cleaner" #05102. Will also get inside the female harness as well. Will that remove the surface oxidation? Never used anything like that so I'm curios. I can see it possibly removing any loose stuff but it would have to chemically react withe the copper oxide if it were to remove the surface layer.
Re: still no spark
[Re: off-roader]
#933442
03/01/09 05:41 PM
Can't say yes to that specifically from memory but can only say I've used both with success. The Radio Shack stuff fixed my Camry's non-functioning door switches to like new operation, but I worked them on/off as I sprayed. It has a lubricate as well as cleaner. The CRC stuff has no lubricant and will evaporate dry. The CRC cleaner says; "...safely dissolve dirt, dust, grease, flux and other contaminants on contact." I guess you could spray as you plug/unplug connectors to rub/clean/wash off crud. I just thought trying to get tiny eraser into contacts would be a problem.
Re: still no spark
[Re: off-roader]
#933443
03/01/09 05:43 PM
I had the same problem of no spark and was able to read the code on the ecu telling me it was the crank angle sensor. After a couple of cranks of it not firing, the check engine light should come on. Read the code and it should give you a good idea of where to look. Let me know what you come up with bc I had the same problem on my 89 Raider
87 Dodge Raider 4.3 Vortec work in progress 89 Dodge Raider 3.0 V6 Fully Restored Links are in my Bio to Photos
