22R >>22RE #935018 03/09/09 01:46 PM
JEFF84 Offline OP
The 22R in my 1984 PickUp has amost 300K miles and is getting tired.
It is starting to use about 2.5 quarts over a 5000 mile period.
So I am considering a engine rebuild or 22RE engine replacement with or without the fuel injection.
I'm not looking for a big project here, I don't have a donor vehicle and it has been awhile getting famailar with the differances in the engines.
I would like to with a few basic questions hopefully the forum can answer:
1. Is there a write up on performing a 22RE install with cross-over to fuel injection to a previously non fuel injected truck ?
2. What all will I need from the Fuel injected vehicle to perform the cross-over ?
3. Does the intake manifold (carburated) or exhaust manifold swap over to the 22RE ?, as I remember one does the other does not.
Jeff
1984 EXT CAB PUP, Weber 32/36, LC Headers, DOA C270, Detroit (Rear), All-Pro Front.
Re: 22R >>22RE [Re: JEFF84] #935019 03/09/09 10:57 PM
Elbow_Greese Offline
There are a few differences in EFI and Carb, as well as motor differences from pre-84 and the 85-95 R/RE's.
If you want to use your exhaust on an EFI block, you'll have to find a 82-84 Celica to get the correct block. Otherwise, you'll be looking at an 85-95 block and need the exhaust manifold as well.
Best way to do the conversion is to have a donor vehicle - and a 2wd will work as well, except for the difference in oil pan/pickup tube, but you can use your current one for that.
If you want to keep the Carb, you'll need to find a pre-84 block for your intake to bolt on, otherwise find a 85-95 block and carb intake/exhaust manifold.
Hope this helps,
Todd
1986 Pickup extracab longbed "Woody edition"
SAS - 33's, 5.29's, lockright rear.
02 IS300 SportCross - my "DD"
94 2wd v6 extracab
04 Outback Wagon- wife's/family car
Re: 22R >>22RE [Re: Elbow_Greese] #935020 03/10/09 05:18 AM
Scerb Offline
http://www.pirate4x4.com/forum/showthread.php?t=316661
Re: 22R >>22RE [Re: Scerb] #935021 03/11/09 04:40 PM
JEFF84 Offline OP
I found some postings by matts that gave a pretty amount of data on the subject. It can be found at: http://www.4x4wire.com/forums/showflat.php?Cat=&Board=UBB11&Number=965519
Thanks <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
Jeff
Re: 22R >>22RE [Re: JEFF84] #935022 03/12/09 05:51 PM
suba Offline
2.5 quarts? Thats all? Thats not even a full oil change...before oil change...its fine! On a serious note though it seems to me that swapping from carb to efi is a fairly big project, especially without a donor vehicle. Collecting all of the necessary parts and wiring could be a pain. That said if you have a junkyard nearby then it might not be that bad if they have a vehicle that you could get all of the parts from, especially if they'll pull them off for you. The nicest thing about having a donor vehicle is being able to look at where the parts are installed and where the wires go, beats a wiring diagram anyday.
86 4runner, pro comp AAL, Kayline Soft top, 31's but all stock
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6039 MB (Peak: 0.6698 MB) Data Comp: Off Server Time: 2026-06-16 22:37:44 UTC
