Re: Lowering Drive Line Support Bearing [Re: NorCalT1] #935105 03/21/09 02:22 AM
N
NorCalT1 Offline OP
I'm in the middle of replacing the bearing and cant get the large nut loose on the end of the drive line joint flange.(keeping the bearing on) I got the lock tab bent back out on the end of the nut but I can't get the nut loose! I don't feel safe putting the truck in gear and using the gears to keep the drive line from rotating, unless thatÆs how I am supposed to do it. <img src="/forums/images/graemlins/confused.gif" alt="" /> The book doesn't say. Impact gun didn't budge it either. Or do you guys remove the drive line and remove the flange nut on the bench w/ a vice? Help Please
Re: Lowering Drive Line Support Bearing [Re: NorCalT1] #935106 03/21/09 02:43 AM
N
NorCalT1 Offline OP
Just got the nut off! <img src="/forums/images/graemlins/smile.gif" alt="" />
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.5941 MB (Peak: 0.6424 MB) Data Comp: Off Server Time: 2026-06-23 03:07:17 UTC
