Oh no, strached my crank - can't believe it
#935357
03/11/09 05:32 PM
I am so depressed. This is going to leak isn't it? <img src="/forums/images/graemlins/frown.gif" alt="" /> ![[Linked Image]](http://img24.imageshack.us/img24/3797/dsc06199.jpg) <img src="/forums/images/graemlins/barf.gif" alt="" /> <img src="/forums/images/graemlins/barf.gif" alt="" /> I was drilling a tiny pilot hole before drilling the hole for a screw for pull the seal. My arm slipped and the drill bit slipped between the crank and the seal <img src="/forums/images/graemlins/frown.gif" alt="" /> All this work and it's still going to drip oil <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: Oh no, strached my crank - can't believe it
[Re: Mad_Scientist]
#935358
03/11/09 05:36 PM
<img src="/forums/images/graemlins/ignore.gif" alt="" /> Maybe you can fill it with something. <img src="/forums/images/graemlins/frown.gif" alt="" />
89 2dr 3.0 AT, manual hubs. 33x12.5 MT gen 2 coils,Cranked front tbars Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
[Re: Tag]
#935359
03/11/09 05:41 PM
Try using some light sandpaper like 200 or so maybe even higher, emery cloth would be good and try to polish it out, your gonna have to clean the crack surface anyway, also you could look into a wear sleeve if there is one available. I've had people at work do alot worse with a screwdriver trying to spin out main bearings. And we just polish them out.
1993 Chevy Suburban 2500- Tow Rig
1991 Mitsubishi Montero LS LWB
SR Parts: Rear Axle Coils Trailing Arms Front Calipers and soon to have UCA's and idler arm. Dual Bouncies Air Lift Airbags Aisins 33x12.50x15 Custom Grooved TSL's
Body lift in the near future.
[Re: Mad_Scientist]
#935360
03/11/09 05:43 PM
Start with a file, if you have a small wetstone would be nice. The file will get the edge off and you the assess it at that point.
From the looks of it once you have filed it the best you can so it will not cut the new seal, install the seal shallow so the lip will run out on the undamaged area.
[Re: OldColt]
#935361
03/11/09 06:28 PM
Emery Cloth, and it'll be alright.
[Re: LandRaider]
#935362
03/11/09 07:38 PM
Sorry for the panic <img src="/forums/images/graemlins/baby.gif" alt="" /> and thanks for the help guys. Does this look OK? I'll polish some more. I have little scotchbrite wheels for my dremel. ![[Linked Image]](http://img11.imageshack.us/img11/9942/dsc06209i.jpg) ![[Linked Image]](http://img9.imageshack.us/img9/1529/dsc06210.jpg) ![[Linked Image]](http://img9.imageshack.us/img9/426/dsc06211f.jpg) Thanks
[Re: Mad_Scientist]
#935363
03/11/09 07:40 PM
Reuben, I think I'd leave it alone and run it. Pretty sure you'll be fine.
[Re: Mad_Scientist]
#935364
03/11/09 07:43 PM
That should be good. Due to the direction of rotation that is not prone to cut the seal. Again when you install the seal do not seat it home, make sure it is solidly and squarely in but leave it out 2 or 3mm so the lip runs on undamaged surface.
[Re: OldColt]
#935365
03/11/09 07:55 PM
Looks good enough for government work.
[Re: ncdieselwrench]
#935366
03/11/09 08:03 PM
looks ok to me.
you can also try to position the lip of the seal to not ride on that spot.
see if any of the parts stores have a "crank saver". its a very thin metal sleeve that slips over the seal surface of the crank.
87 Montero V6 SWB auto. dual bouncies 89 Montero V6 SWB 5 speed. dual bouncies 97 3000gt VR4 upgraded turbos, 10:1, E85 91 Stealth TT twin 18Gs, cams/heads, E85 03 cobra lightly modded <img src="/forums/images/graemlins/lol.gif" alt="" /> 91 MR2 turbo
