Page 3 of 4 1 2 3 4
Re: Oh no, strached my crank - can't believe it [Re: sparkem] #935377 03/13/09 02:49 AM
Mad_Scientist Offline OP
'Cause you're the Stig, right?
You know it Larry <img src="/forums/images/graemlins/kewl.gif" alt="" /> But, shhhh, [whisper] it's a secret [/whisper] <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
if you dont have any leaks in the next week or so you should be ok
Fingers crossed <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Oh no, strached my crank - can't believe it [Re: Mad_Scientist] #935378 03/13/09 07:44 PM
You know I was thinking yesterday how amazing it is that I got such helpful replies and so quickly when I posted the first pic. You guys are awesome. So thanks again to the support group! <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Oh no, strached my crank - can't believe it [Re: Mad_Scientist] #935379 03/13/09 10:14 PM
hazy_daze Offline
Group Hug!!!
Wait, wrong forum <img src="/forums/images/graemlins/cyclops.gif" alt="" />
Re: Oh no, strached my crank - can't believe it [Re: hazy_daze] #935380 03/14/09 02:54 AM
Group Hug!!!
Re: Oh no, strached my crank - can't believe it [Re: hazy_daze] #935381 03/14/09 04:11 AM
Grasscat Offline
Group Hug!!!
Wait, wrong forum
Hugs are ok larry, it's that other stuff that's weird. <img src="/forums/images/graemlins/lol.gif" alt="" />
Michael j
TreadLightly! Trainer
Re: Oh no, strached my crank - can't believe it [Re: Grasscat] #935382 03/14/09 06:17 AM
87Montero Offline
Group Hug!!!
Wait, wrong forum
OK, back to the gay pile... (south park)
Re: Oh no, strached my crank - can't believe it [Re: 87Montero] #935383 05/13/09 08:23 PM
Just thought I'd drag this thread up to report no signs of any oil leaks after 5k miles. Fingers crossed that it stays that way for quite a while <img src="/forums/images/graemlins/kewl.gif" alt="" />
Thanks again for your help on this one fellas <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Oh no, strached my crank - can't believe it [Re: Mad_Scientist] #935384 05/17/09 12:57 AM
KrzyDav Offline
I'm needing to replace my seal and T belt again real soon.
I takes mine about a month to start leaking. It developes "a spray" pattern across the pan and all over the trans cross beam mt. Eventually the belt is soaked.
A local machine shop says liquid steal the key <img src="/forums/images/graemlins/confused.gif" alt="" />, my keyway <img src="/forums/images/graemlins/frown.gif" alt="" />is damaged. I was thinking maybe some kinda shim to make the H.B. center better--- suggestion appreciated-.
Still trying to get up the bucks for this Hyundai engine.
dave h.
Re: Oh no, strached my crank - can't believe it [Re: KrzyDav] #935385 05/17/09 01:07 AM
FrankR Offline
I don't see why a damaged keyway would cause the seal to leak after a month. It sounds more like the seal surface is no longer smooth. You could use a seal surface repair sleeve and maybe it would solve the sealing problem, but you'd still be left with a problem with the harmonic balancer. Filling the keyway with JB Weld might work, but it's not such a good idea unless you never want to remove the woodruff key again. OTOH, maybe it'll work long enough to buy some time to find another engine or crankshaft.
Frank
Re: Oh no, strached my crank - can't believe it [Re: FrankR] #935386 05/18/09 12:55 AM
Yeah using WB weld on a damaged keyway is a famous fix for the short nose crank damage common on early, early Miatas. Many have done the fix successfully but it doesn't last forever.
Good luck <img src="/forums/images/graemlins/kewl.gif" alt="" />
Page 3 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6473 MB (Peak: 0.7566 MB) Data Comp: Off Server Time: 2026-06-10 04:27:34 UTC
