Re: Oh no, strached my crank - can't believe it
[Re: vr4]
#935367
03/11/09 08:59 PM
[Re: sparkem]
#935368
03/11/09 09:12 PM
Thanks fellas. Will do as you suggest Charlie, re seal lip. Fingers crossed. <img src="/forums/images/graemlins/lol.gif" alt="" /> That brought a smile to my face for the first time in a few hours! WWSD? For the record The Stig said sh!!!!!!!!t <img src="/forums/images/graemlins/smile.gif" alt="" />
[Re: Mad_Scientist]
#935369
03/12/09 12:54 AM
I did that ,,,,so I didn't want to take a chance with such an important seal..
Get a Speedy Sleeve, <img src="/forums/images/graemlins/kewl.gif" alt="" /> ( buy 2 for the one you mess up).
$18.00 at Kragen. I used a crank bolt and a socket to Slowly press it on. I did not used sleeve retainer glue.
Mines 2 years old.
dave h. '89 Raider V6 5spd;Aisin Hubs;; Gen2 LS: frt. brakes, rear coils;U.C.arms;R.trailing arms;idler arm; rear LSD axle w.disc brakes ;2 battery system for Dog's fan; relocated ECU; custom bumpers;J.Baker receiver;Conferr roofrack; t-bar crank.
[Re: KrzyDav]
#935370
03/12/09 02:12 PM
Speedy sleeves will slide right on if warmed up in the oven first....
[Re: raiderquest]
#935371
03/12/09 07:16 PM
Never heard of these sleeves, though I get what they are about. Are they then thin enough and/or the seal has enough stretch that the OEM seal still works? ot do you have to get a larger I.D. seal?
[Re: MontyMcV]
#935372
03/12/09 08:18 PM
Never heard of these sleeves, though I get what they are about. Are they then thin enough and/or the seal has enough stretch that the OEM seal still works? ot do you have to get a larger I.D. seal? Speedy sleeves are made of stainless steel. I have used them on harmonic balancer snouts and even on spindels after a bearing has siezed and made it unfit to put a new bearing on. They are thin enough that stock seals still work perfectly and the stainless is strong enough to apply pressure to install them.They have a removable flange on one end that lets you drive them on. I have always heated the sleeve and if possible, put the other part (harmonic balancer) in the freezer. Heat/cold works like magic. Speedy sleeves are a life saver in some cases.
[Re: raiderquest]
#935373
03/12/09 09:44 PM
Heat/cold works like magic. Amen to that <img src="/forums/images/graemlins/kewl.gif" alt="" /> All back together and running like a champ...apart from some minor idle issues. I hope the crank seal will be OK. Only time will tell I guess. I'd rather not see the timing belt on this truck for quite a while <img src="/forums/images/graemlins/baby.gif" alt="" /> Besides, I can't afford it <img src="/forums/images/graemlins/cyclops.gif" alt="" /> Phew! That was a marathon!! More the valve guide seals later... <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: Mad_Scientist]
#935374
03/12/09 09:56 PM
Glad it's back together Reuben <img src="/forums/images/graemlins/kewl.gif" alt="" />
You should be fine.
'Cause you're the Stig, right? <img src="/forums/images/graemlins/smile.gif" alt="" />
[Re: hazy_daze]
#935375
03/12/09 10:58 PM
[Re: sparkem]
#935376
03/13/09 12:19 AM
if you dont have any leaks in the next week or so you should be ok
87 Montero V6 SWB auto. dual bouncies 89 Montero V6 SWB 5 speed. dual bouncies 97 3000gt VR4 upgraded turbos, 10:1, E85 91 Stealth TT twin 18Gs, cams/heads, E85 03 cobra lightly modded <img src="/forums/images/graemlins/lol.gif" alt="" /> 91 MR2 turbo
