Page 4 of 4 1 2 3 4
Re: Oh no, strached my crank - can't believe it [Re: 87Montero] #935387 05/20/09 11:56 PM
joestruck Offline
Group Hug!!!
Wait, wrong forum
Hugs are ok larry, it's that other stuff that's weird. <img src="/forums/images/graemlins/lol.gif" alt="" />
OK, back to the gay pile... (south park)
C'MON BOY! SQUEAL LIKE A FAN BELT!!!
Re: Oh no, strached my crank - can't believe it [Re: FrankR] #935388 05/21/09 03:36 AM
KrzyDav Offline
I've got a speedy sleve on there so the sealing surface is smooth. ( unless I did something "invisable " wrong). The sleeve had no snap off part on it that's used as for installment as someone posted on here that had installed a speedy.
My problem is a hammer/ compressed snout I beleive. I got a good 91 H.B. with the holes for a spanner that the 89 didn't have. Although my snout ools smooth I believe is is smaller now and the H.B. mounts offbalance, ie not centering properly. The snout is a slight taper???right ???
There are no spects on meassuring the snout. The wobble Is causing the misty leakage.
I was wondering if some kinda bronze foil would work.
dave h.
Re: Oh no, strached my crank - can't believe it [Re: KrzyDav] #935389 05/21/09 04:13 AM
FrankR Offline
Not that I'm aware of - mine's straight.
Nope - if the seal was working, there'd be no oil to get past it and on to the wobbly balancer.
If you have a wobbly balancer, you have either a wrong balancer or the crankshaft snout is beyond repair.
That's a patch I wouldn't want to try.
Frank
Re: Oh no, strached my crank - can't believe it [Re: FrankR] #935390 05/23/09 12:59 AM
KrzyDav Offline
yes beyond repair <img src="/forums/images/graemlins/frown.gif" alt="" />
dave h.
Page 4 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6116 MB (Peak: 0.6686 MB) Data Comp: Off Server Time: 2026-06-10 01:34:30 UTC
