Re: Oh no, strached my crank - can't believe it
[Re: sparkem]
#935377
03/13/09 02:49 AM
'Cause you're the Stig, right? You know it Larry <img src="/forums/images/graemlins/kewl.gif" alt="" /> But, shhhh, [whisper] it's a secret [/whisper] <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> if you dont have any leaks in the next week or so you should be ok Fingers crossed <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: Mad_Scientist]
#935378
03/13/09 07:44 PM
You know I was thinking yesterday how amazing it is that I got such helpful replies and so quickly when I posted the first pic. You guys are awesome. So thanks again to the support group! <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: Mad_Scientist]
#935379
03/13/09 10:14 PM
Group Hug!!!
Wait, wrong forum <img src="/forums/images/graemlins/cyclops.gif" alt="" />
[Re: hazy_daze]
#935380
03/14/09 02:54 AM
Group Hug!!!
Wait, wrong forum <img src="/forums/images/graemlins/cyclops.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
[Re: hazy_daze]
#935381
03/14/09 04:11 AM
Group Hug!!!
Wait, wrong forum Hugs are ok larry, it's that other stuff that's weird. <img src="/forums/images/graemlins/lol.gif" alt="" />
Michael j
TreadLightly! Trainer
[Re: Grasscat]
#935382
03/14/09 06:17 AM
Group Hug!!!
Wait, wrong forum Hugs are ok larry, it's that other stuff that's weird. <img src="/forums/images/graemlins/lol.gif" alt="" /> OK, back to the gay pile... (south park)
1999 Mitsu Montero - Crappy Weather 1992 Isuzu Pickup - Zombie Apocalypse 2008 Saturn Sky Redline - Nice Weather
[Re: 87Montero]
#935383
05/13/09 08:23 PM
Just thought I'd drag this thread up to report no signs of any oil leaks after 5k miles. Fingers crossed that it stays that way for quite a while <img src="/forums/images/graemlins/kewl.gif" alt="" />
Thanks again for your help on this one fellas <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: Mad_Scientist]
#935384
05/17/09 12:57 AM
I'm needing to replace my seal and T belt again real soon. I takes mine about a month to start leaking. It developes "a spray" pattern across the pan and all over the trans cross beam mt. Eventually the belt is soaked. A local machine shop says liquid steal the key <img src="/forums/images/graemlins/confused.gif" alt="" />, my keyway <img src="/forums/images/graemlins/frown.gif" alt="" />is damaged. I was thinking maybe some kinda shim to make the H.B. center better--- suggestion appreciated-. Still trying to get up the bucks for this Hyundai engine.
dave h. '89 Raider V6 5spd;Aisin Hubs;; Gen2 LS: frt. brakes, rear coils;U.C.arms;R.trailing arms;idler arm; rear LSD axle w.disc brakes ;2 battery system for Dog's fan; relocated ECU; custom bumpers;J.Baker receiver;Conferr roofrack; t-bar crank.
[Re: KrzyDav]
#935385
05/17/09 01:07 AM
I don't see why a damaged keyway would cause the seal to leak after a month. It sounds more like the seal surface is no longer smooth. You could use a seal surface repair sleeve and maybe it would solve the sealing problem, but you'd still be left with a problem with the harmonic balancer. Filling the keyway with JB Weld might work, but it's not such a good idea unless you never want to remove the woodruff key again. OTOH, maybe it'll work long enough to buy some time to find another engine or crankshaft.
Frank
[Re: FrankR]
#935386
05/18/09 12:55 AM
Yeah using WB weld on a damaged keyway is a famous fix for the short nose crank damage common on early, early Miatas. Many have done the fix successfully but it doesn't last forever.
Good luck <img src="/forums/images/graemlins/kewl.gif" alt="" />
