Downey Torsion Bars
#937573
03/27/09 02:50 AM
On my local CraigsList someone is selling Downey Torsion bars. Add says; "downey oversize torsion bar for 86-95 IFS 4x4 trucks/ 4runners, provides about 2in of lift." For $100. IÆm guessing its a set, not just one bar. (havenÆt called yet) My question is; will these fit my 96 T100 4x4??
Re: Downey Torsion Bars
[Re: NorCalT1]
#937574
03/27/09 05:12 AM
Check Downey website for fit info - may be seller is relying on outdated pre-96 spec data.
Jeff 96 T100 SR5 4WD Ext Cab, Warn Hubs, HD torsion bars, Bilsteins, Camper Shell, TJM bar, factory 31 x 10.5's, Powertrax No-slip rear, Recaro driver's bucket
[Re: jmoser]
#937575
03/27/09 06:11 AM
Downey web site shows the same part # for T-bars used on 4WD 93-98 T100's and 1986-95 4WD Pickup & 4 Runner, with the same price of $158. So now I need to call the person to make sure there part # is the same(48186), and to get the price down a bit. <img src="/forums/images/graemlins/wink.gif" alt="" /> Does anyone have any input on the Downey T-bars?? IÆve read the discussions about SAW T-bars but not much on Downey.
[Re: NorCalT1]
#937576
03/29/09 07:48 PM
I have a sneaking suspicion Downey's may be made by Rancho. I used Rancho bars for a couple of years and liked them. They carried the weight of the winch well and stood up to some considerable thumping. I believe they're still in use by Honger on here.
~Adam  96 T100: D44, lockers and stuff
[Re: adam]
#937577
03/29/09 11:02 PM
Well I called the guy and he gave me a different part #, close but not the same.(48161) So I passed on those bars but I see on ebay there are SAW T-bars for $150+shipping. They are listed for 1986-1994 4WD Toy's. Waiting for a reply from the seller, if they will fit T100 4x4's. http://cgi.ebay.com/ebaymotors/ws/e...=STRK:MEWAX:IT&item=220384571006 Is that a good price?? I am only adding new larger T-bars because I am upgrading to 35" tires. Is there any thing else I should do/upgrade before putting 35's on?? I have front gears(still looking for best price on rear gears), I have the clearance, I have aisin hubs installed, Toyota just replaced my relay rod(recall), and I am going to beef up the idler arm or fork out the $$$ for the Total Chaos arm. Anything I am missing?? I have stock bumpers for the time being(no extra weight), Do you guys think I need to up grade the T-bars for just adding 35x12.5 a/t tires?? Thanks for any help.
[Re: NorCalT1]
#937578
03/30/09 01:35 AM
I doubt you need to, but if you add a heavier bumper or a winch it will help hold the front up.
[Re: CJMT100]
#937579
03/30/09 01:51 AM
Toyota Moderator
SAW stuff is high quality.
Thicker torsion bars are simply stiffer springs. If that is what you want, then go for it. Larger tires are not usually a reason for wanting stiffer springs though.
If you want lift without increasing the stiffness of the springs, crank up the stock bars.
[Re: adam]
#937580
03/30/09 02:07 AM
I have a set of Downeys on my truck. Been on there since about 03. No problems. I have em a bit tight though cause when I hook up to a trailer the front end becomes a diving board. It's the only thing I can figure is causing that. Also have a TJM winch bull bar (no winch) on it. My stock ones are sitting in storage........
[Re: ErikB]
#937581
03/30/09 02:46 AM
Thanks for all the quick replies! So it sounds like I should take the $$ I was going to use to buy T-bars and put it towards the Total Chaos arm. As much as I hate spending that much $$$ on that little part! I worry the stock idler arm will crap-out once 35's are on. Anyone have a good link for rear gears?
