Page 2 of 5 1 2 3 4 5
Re: 01 sportage 4" susp lift [Re: 69442] #937906 04/18/09 01:13 AM
Hydra747 Offline
Congrats on the UPURKIA lift <img src="/forums/images/graemlins/kewl.gif" alt="" />
Did not know that it is 4"........Awesome work Everet <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: 01 sportage 4" susp lift [Re: Hydra747] #937907 04/18/09 01:27 AM
k120189 Offline
yup i have one of everets 4 inch installed as well..if you have some questions give me a hollar im also on aim as idrift240s
<a href="www.pittsfieldcustomsclub.com/sportage.html" target="_blank">98 sportage</a>: warn manual hubs,upyourkia spacers, 104 tj springs, 235/75/r15 BFG T/A KO, tracker rims, cone air filter, custom cat-back with a skunk2 muffler. gonna be a 2.3L
Re: 01 sportage 4" susp lift [Re: k120189] #937908 04/22/09 03:40 AM
6
69442 Offline OP
Thanks, I'm gonna give it a go this thursday evening so I can have it aligned by saturday. Got a lot of beer on hand and a couple of buddy's who want to stupervise!! <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
LIFT OR BUST! 2001 Sportage EX 4dr 4WD with 300,210 miles & counting .....
____o_o
l_l_l\___\___
l----[o]==[o]
l----==[--]==
()_)()_)--()_)
Re: 01 sportage 4" susp lift [Re: 69442] #937909 04/22/09 10:26 PM
Dryver Offline
I got the 3" lift from Everet. Did the back end last weekend, but didn't have time to get to the front yet, so I'm ass-up for the moment. <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> Hope to finish it this weekend.
01 Convertible; Electric Fan; 3" Up Your Kia lift spacers; Tj 104's; 31x10.5x15's on Centerlines; Rear LSD.
GONE, all I have left are a few spare parts and the wheels.
Re: 01 sportage 4" susp lift [Re: Dryver] #937910 04/23/09 12:20 AM
DennisThompson Offline
The front should not be that hard to get back together and I never had to use a hammer.
1st, Make sure your lower A-arms bolts are loose at the frame.
2nd, Make sure your sway bar is disconeted.
3rd, Make sure you leave your top bolts loose where the spacers bolts onto the strut tower untill you get the four bolts on top of the strut fork tight.
4th, leave the bottom nut on the strut fork loose and install the top inside nut and bolt first on the top of the fork and with a prybar, pry on the strut to push the rest of the bolts in.
5th, tighten everything up.
Hope this helps, Dennis
Re: 01 sportage 4" susp lift [Re: DennisThompson] #937911 04/23/09 12:35 AM
6
69442 Offline OP
Thanks for that!! Sounds like you've done this a few times and figured out how to make it a little easier on yourself. <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> I'm tearing into mine tomorrow and will refer to this as I go <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
____o_o
l_l_l\___\___
l----[o]==[o]
l----==[--]==
()_)()_)--()_)
Re: 01 sportage 4" susp lift [Re: 69442] #937912 04/23/09 01:30 AM
Everet Offline
Dennis is the KING of UPYOURKIA SPACERS!!! He invented them.
Everet <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 01 sportage 4" susp lift [Re: 69442] #937913 04/23/09 10:22 PM
Dryver Offline
Preliminary step done. Everything is soaking in PB Blaster.
Just to clarify, I need to loosen both of the large bolts/nuts holding each lower A-arm to the frame. Any chance I can get away without doing this step since I have the 3" lift rather than the 4"? If not, what size are those nuts, and how large of a breaker bar should I be looking at to loosen those suckers?
Also, Everet, my coworker and I came up with a suggestion to modify the UpYourKia spacers that may make installation easier, if it's feasible. Instead of welding the bolts to the spacer, how about welding nuts instead and drop the bolts from the top of the shock towers to tighten into weld nuts on the spacers? This would give you 7/8" more clearance to get everything back into place during install.
Re: 01 sportage 4" susp lift [Re: Dryver] #937914 04/24/09 01:35 AM
The lower a-arm is very hard to push down far enough to get the strut back in with the spacer, The rubber bushings are tight. You can get by with the 3" but it will be easer with them loose.
Dennis
Re: 01 sportage 4" susp lift [Re: Dryver] #937915 04/24/09 05:16 AM
Everet Offline
I'll look into the nut idea. Your right in that it could aid in the ease of installation.
Everet
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6474 MB (Peak: 0.7534 MB) Data Comp: Off Server Time: 2026-06-22 01:05:38 UTC
