Re: Gen2 Steering Box in Gen1
[Re: rxinhed]
#937981
03/31/09 01:09 AM
Yes there's a Gen II to gen I compatability thread already...like offroader said do a search. I would post a direct link and do the work for you but I'm posting this from a phone.
99 Gen 2.5, fixing blown head gasket 89 SWB- 33's, ARB Front locker, SR rear locker/axle, SR F brakes, winch, WST Offroad Armor all Around, 2.85 Aussie T-case Gears (SOLD) Sold: (2) 95 SR's, 86 SWB, 90LWB, 91 LWB -Can Change a timing belt in my sleep..
[Re: justice]
#937982
03/31/09 01:23 AM
I've seen that thread, I think there might have been a couple. I've been researching stuff that swaps over that I can get at the yard. Just couldn't find a solid answer about whether the steering box would work. I'll pick one up and let you guys know how it goes.
1989 Montero 4dr V6 3.0l
[Re: rxinhed]
#937983
03/31/09 01:32 AM
Didn't Justice start a Gen II to Gen I compatibility thread last year? <img src="/forums/images/graemlins/confused.gif" alt="" /> Yep.
[Re: off-roader]
#937984
03/31/09 02:10 AM
It would be nice to have a compatability list of stuff that will work on gen I. good luck <img src="/forums/images/graemlins/patriot.gif" alt="" /> Search is also your friend (see here.)... but you haven't been on here for long so I normally wouldn't tell you that. I included the link to Justice's thread in my reply above but I guess it was missed.
[Re: off-roader]
#937985
03/31/09 01:09 PM
It would be nice to have a compatability list of stuff that will work on gen I. good luck <img src="/forums/images/graemlins/patriot.gif" alt="" /> Search is also your friend (see here.)... but you haven't been on here for long so I normally wouldn't tell you that. I included the link to Justice's thread in my reply above but I guess it was missed. Yep, I missed it... <img src="/forums/images/graemlins/smile.gif" alt="" />
[Re: hazy_daze]
#937986
03/31/09 04:52 PM
Yes swapping the steering gear from the gen 2 makes turning 35+ size tires effortless, I really don't think this is a good swap for some one with smaller than 35's. I don't think you would be able to control the truck with tiny tires with the gen 2 steering gear. You can seriously steer the truck at a standstill with your finger tip.
[Re: TOASTY]
#937987
03/31/09 05:21 PM
This is a swap you've done, isn't it? Did you have to change anything like the pump or the lines? Or did it just bolt right in with existing hardware?
[Re: hazy_daze]
#937988
03/31/09 09:27 PM
yes we used the steering gear from my old '94 SR on lordtrunks 89 v6 swb, I'm pretty sure one hole doesn't line up and you'll need to drill and that was it the rest swapped right over.
[Re: TOASTY]
#937989
03/31/09 09:48 PM
the top holes don't line up you'll need to oval them out and use a heft washer like what kevinc did on his or cut the top mout off the frame and make a new one then weld it on.
89 2 dr turbo diesel 89/88 "Backwoods sas"
[Re: lordtrunks]
#937990
04/01/09 12:31 AM
I was looking at a 91 LWB to put on my 89 SWB. They fitting/tubing is larger, as Grasscat said. The top bolts don't line up . I guess this is the same problems as gen2s.
dave h. '89 Raider V6 5spd;Aisin Hubs;; Gen2 LS: frt. brakes, rear coils;U.C.arms;R.trailing arms;idler arm; rear LSD axle w.disc brakes ;2 battery system for Dog's fan; relocated ECU; custom bumpers;J.Baker receiver;Conferr roofrack; t-bar crank.
