Re: Gen2 Steering Box in Gen1 [Re: rxinhed] #937981 03/31/09 01:09 AM
justice Offline
Yes there's a Gen II to gen I compatability thread already...like offroader said do a search. I would post a direct link and do the work for you but I'm posting this from a phone.
Re: Gen2 Steering Box in Gen1 [Re: justice] #937982 03/31/09 01:23 AM
89montero Offline OP
I've seen that thread, I think there might have been a couple. I've been researching stuff that swaps over that I can get at the yard.
Just couldn't find a solid answer about whether the steering box would work. I'll pick one up and let you guys know how it goes.
1989 Montero 4dr V6 3.0l
Re: Gen2 Steering Box in Gen1 [Re: rxinhed] #937983 03/31/09 01:32 AM
hazy_daze Offline
Didn't Justice start a Gen II to Gen I compatibility thread last year? <img src="/forums/images/graemlins/confused.gif" alt="" />
Yep.
Re: Gen2 Steering Box in Gen1 [Re: off-roader] #937984 03/31/09 02:10 AM
It would be nice to have a compatability list of stuff that will work on gen I. good luck <img src="/forums/images/graemlins/patriot.gif" alt="" />
Search is also your friend (see here.)... but you haven't been on here for long so I normally wouldn't tell you that.
I included the link to Justice's thread in my reply above but I guess it was missed.
Re: Gen2 Steering Box in Gen1 [Re: off-roader] #937985 03/31/09 01:09 PM
hazy_daze Offline
Yep, I missed it... <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Gen2 Steering Box in Gen1 [Re: hazy_daze] #937986 03/31/09 04:52 PM
Yes swapping the steering gear from the gen 2 makes turning 35+ size tires effortless, I really don't think this is a good swap for some one with smaller than 35's. I don't think you would be able to control the truck with tiny tires with the gen 2 steering gear. You can seriously steer the truck at a standstill with your finger tip.
Re: Gen2 Steering Box in Gen1 [Re: TOASTY] #937987 03/31/09 05:21 PM
hazy_daze Offline
This is a swap you've done, isn't it? Did you have to change anything like the pump or the lines? Or did it just bolt right in with existing hardware?
Re: Gen2 Steering Box in Gen1 [Re: hazy_daze] #937988 03/31/09 09:27 PM
yes we used the steering gear from my old '94 SR on lordtrunks 89 v6 swb, I'm pretty sure one hole doesn't line up and you'll need to drill and that was it the rest swapped right over.
Re: Gen2 Steering Box in Gen1 [Re: TOASTY] #937989 03/31/09 09:48 PM
lordtrunks Offline
the top holes don't line up you'll need to oval them out and use a heft washer like what kevinc did on his or cut the top mout off the frame and make a new one then weld it on.
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: Gen2 Steering Box in Gen1 [Re: lordtrunks] #937990 04/01/09 12:31 AM
KrzyDav Offline
I was looking at a 91 LWB to put on my 89 SWB.
They fitting/tubing is larger, as Grasscat said.
The top bolts don't line up . I guess this is the same problems as gen2s.
dave h.
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6429 MB (Peak: 0.7530 MB) Data Comp: Off Server Time: 2026-07-16 03:24:09 UTC
