Rating: 1
Page 2 of 9 1 2 3 4 5 6 7 8 9
Re: 2.3L Stroker info post [Re: k120189] #938167 04/22/09 04:56 AM
DennisThompson Offline
Do you have to over bore for the SR20 pistons? If so how much? Do you have part #s for the pistons that work? When I find a piston that I know works then I will get the Probe flywheel modified for the Kia crank postion sensor.
Dennis
Re: 2.3L Stroker info post [Re: DennisThompson] #938168 04/22/09 05:41 AM
Everet Offline
Stock is 86mm I believe so yes you would have to. Also need to machine room for stock rod.
Re: 2.3L Stroker info post [Re: Everet] #938169 04/22/09 02:07 PM
k120189 Offline OP
stock bore for sr20 is 86mm so u only have to over bore if u want to. get u a part number in a bit
<a href="www.pittsfieldcustomsclub.com/sportage.html" target="_blank">98 sportage</a>: warn manual hubs,upyourkia spacers, 104 tj springs, 235/75/r15 BFG T/A KO, tracker rims, cone air filter, custom cat-back with a skunk2 muffler. gonna be a 2.3L
Re: 2.3L Stroker info post [Re: k120189] #938170 04/29/09 02:20 PM
k120189 Offline OP
thru http://importperformanceparts.net/
the part number for sr20de pistons with rings is PAD30
$36 a peice
$144 for four
you can order std .020 and .040 over
Re: 2.3L Stroker info post [Re: k120189] #938171 04/30/09 07:46 AM
fokion Offline
Found also that if it is any help..
They have a US branch too..
http://www.flatlander-ipp.nl/hpkits/pek-kia.shtml
Re: 2.3L Stroker info post [Re: fokion] #938172 04/30/09 02:11 PM
k120189 Offline OP
yea they are actualy a part of import performance parts
good link tho
if anyone can find a better deal then 144+ship for the sr20 pistons let me know
Re: 2.3L Stroker info post [Re: k120189] #938173 05/01/09 02:34 AM
I was thinking of going back stock but I think this just changed my mind. Thanks for the info.
Dennis
Re: 2.3L Stroker info post *DELETED* [Re: DennisThompson] #938174 05/02/09 02:22 AM
5
5jackz Offline
Post deleted by DamKia
2000 with Eibach Suspension lift,Warn man. hubs,K&N air filter,15x8 mags with 31's, 3.75" body lift.
Re: 2.3L Stroker info post [Re: 5jackz] #938175 05/02/09 02:47 PM
k120189 Offline OP
can the post above me be deleted not to be an ass or anyhting but it has nothing to do with this thread.
dennis if u have any more questions ask em and i will look it up.
theres something about using rx7 injectors for more fuel if i find it again i'll post it
Re: 2.3L Stroker info post [Re: k120189] #938176 05/02/09 11:25 PM
DEFBOY35 Offline
if i remember correctly, using the sr20 pistons will lower the compression quite a bit, which is fine if you will be using them in a boosted application. but if you are sticking to NA then it may not be the best option
2000 SPORTY, DEF BOY customs, mmm....lockers, mmm... gears, mmm... double transfer case, mmm... stroker
http://www.cardomain.com/ride/2377991
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.008s) Memory: 0.6476 MB (Peak: 0.7505 MB) Data Comp: Off Server Time: 2026-10-21 14:32:46 UTC
