Page 2 of 3 1 2 3
Re: How are you guys lifting the leaf spring rear??? [Re: K_Raider] #938354 04/01/09 03:09 PM
W
whitelespaul Offline
I used 3/4 ton Chevy 73- 87 add-a-leaf in place of the 1/2" overload spring on my Mitsu truck. It improved the load carry and made the entire spring pack lift about 2".
83 mitsu flat bed 2.6l weber, 88 auto tranny, 2" body lift, 4.625 LSD, 235/85-16E mudders (33 x 9.50).
Re: How are you guys lifting the leaf spring rear??? [Re: whitelespaul] #938355 04/01/09 03:34 PM
K_Raider Offline OP
The only thing I worry about with the add-a-leaf is making the ride too harsh. I will not be doing any towing with it. I have a 99 2500 Dodge for that. I am leaning toward the shackles so it will still flex. I like the balljoint spacer idea. I am assuming that is so the angle is not thown off after cranking the torsion bars.
88 Raider- sitting on a full size Chevy frame with 35.5x11.50x16 Dyna Torque II tractors
89 Montero- stock 2.6 M/T 30-9.50 BFG all terrains on American Racing Wheels
99 2500 Ram- 285-75-16 Uniroyal all terrains,straight pipes with no cat (yes its loud)
Re: How are you guys lifting the leaf spring rear??? [Re: K_Raider] #938356 04/01/09 03:48 PM
Tag Offline
I do not run a bj spacer. Many people do not like them. I have gen 2 uca. Besides I dont know if you can run a BJ spacer on Gen1 arms.
89 2dr 3.0 AT, manual hubs. 33x12.5 MT
gen 2 coils,Cranked front tbars
Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
Re: How are you guys lifting the leaf spring rear??? [Re: Tag] #938357 04/01/09 04:05 PM
K_Raider Offline OP
Yeah, I remember you telling me that. I thought maybe the spacers were so you didnt have to change them. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: How are you guys lifting the leaf spring rear??? [Re: K_Raider] #938358 04/01/09 06:56 PM
I never liked the extended shackles on the rear, as it hurts departure angle. I like the re-arch, perhaps plus the add a leaf if you have load problems.
Re: How are you guys lifting the leaf spring rear??? [Re: fasteddy] #938359 04/01/09 09:18 PM
Tag Offline
re-arched is probably the way to go depending on the price.
Re: How are you guys lifting the leaf spring rear??? [Re: Tag] #938360 04/01/09 09:25 PM
FatTony Offline
I made some longer shackles and I hate them, they get hung up on stuff a lot. I also took out the two middle leaves in the pack and replaced them with Dodge dakota leaves, the leaves are a little thicker and had a little more arch. That gave me about 2", but my stock springs were pretty sagged.
88 Raider sas, doubler, boggers
Re: How are you guys lifting the leaf spring rear??? [Re: FatTony] #938361 04/02/09 12:29 AM
K_Raider Offline OP
Price is what I was thinking. I haven't checked but I bet its expensive. I don't like the thought of them hanging so low either but it may be the only way I can afford it.
Re: How are you guys lifting the leaf spring rear??? [Re: K_Raider] #938362 04/02/09 01:37 AM
CapnCrunch Offline
Summit Racing
Get new bushings for the front shackles from a 1983 Toyota 4x4 pickup from your local Toyota parts department.
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: How are you guys lifting the leaf spring rear??? [Re: CapnCrunch] #938363 04/02/09 01:50 AM
K_Raider Offline OP
I think 94 bones just for some bent metal and bolts is crazy. Thanks for the link though. I think I will make my own. I'm just wondering if I should add 2" to my stock ones. I got access to welders, torches, and metal. The hardware store will have grade 8 bolts. And I guess you only have to put them on the back of the back leafspring? Any thoughts?
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6442 MB (Peak: 0.7515 MB) Data Comp: Off Server Time: 2026-06-17 04:14:33 UTC
