Ditching the reed valve on Raider? #938547 04/02/09 09:10 PM
G
GUNIT Offline OP
I have an 89 Raider with 2.6 That is pretty much built and only used in the bush. I read a couple posts back that I can ditch the reed valve by unscrewing pipe from manifold and put a quarter in there and screw fitting back on? Do I just plug the vacuum hose off that runs to it? and do I just leave the opening on the air cleaner where the big hose went open?
89 Raider 2.6 with 32x9.50 Tsl Bias on stock rims turned inside out. Yota shackles in rear front T bars cranked no sway bar,ditched reed valve and capped with quarter
Re: Ditching the reed valve on Raider? [Re: GUNIT] #938548 04/03/09 05:56 PM
I cut off the steel pipe and crimped it shut and welded the edge, AND put a quarter in there, too. Just cap the vac line. I blocked off the air cleaner hole.
Re: Ditching the reed valve on Raider? [Re: fasteddy] #938549 04/03/09 08:20 PM
G
GUNIT Offline OP
Thanks fasteddy I dont have smog check where I live and it pretty much stays in the bush, The more crap I can get off this motor the better.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5920 MB (Peak: 0.6449 MB) Data Comp: Off Server Time: 2026-06-10 05:55:01 UTC
